Sharpening chisels with an angle grinder
Forum topic by newbiewoodworker posted 953 days ago 2614 views 0 times favorited 18 replies Add to Favorites Watch
View newbiewoodworker's profile
newbiewoodworker
659 posts in 992 days
953 days ago
I was wondering what works better for sharpening chisels with an angle grinder… A flap disk, or a grinding wheel? I asked my shop teacher if it was safe to do with with an angle grinder, and he said yea.. so I am not so concerned with safety… because I Plan to hold on for dear life and that was reassuring…
But what is better? I watched the service tech use a flap disk the other day to put a bevel on that pin that holds the bandsaw motor in place… it seemed to do it fairly quickly… but is this better than a grinding disk/wheel?
There is also a large price difference… 10 grinding wheels is $8 at HF… at homedepot, flap disks are $5.30 a disk… they are $5 at HF… but I would make up that 30c in gas…
-- "Ah, So your not really a newbie, but a I betterbie."
18 replies so far
View DavidFisher's profile
DavidFisher
60 posts in 1862 days
#1 posted 953 days ago
I wouldn’t be inclined to use an angle grinder for this type of application. They have a way of grabbing things and tossing them unless they are securely fastened.
View Jamie Speirs's profile
Jamie Speirs
3668 posts in 1022 days
#2 posted 953 days ago
Just get a cheap oil stone.
Then your sharpening is free, SAFE and your not going to …..
your chisels.
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
newbiewoodworker
#3 posted 953 days ago
Im not worried about tossing things… believe me… if I had to, Ill mount the darned thing to the table…
newbiewoodworker
#4 posted 953 days ago
Besides… they are cheap… if one goes through the wall into the laundry room… it only cost me a buck or so…
View Sawdust4Blood's profile (online now)
Sawdust4Blood
321 posts in 1187 days
#5 posted 953 days ago
I would forget the angle grinder. Sharpen them by hand with a stone or diamond plate. It’s an important skill to learn, will give you a better edge, and it’s safer for both you and the chisel. I sharpen my chisels with waterstones (up to a 5000 grit Japanese stone). If you keep them up, it doesn’t take much time to renew an edge and mine are sharp enough to shave with. The key to making an edge sharp is consistency in the angle you grind. Maintaining consistency for a really great edge is nigh on impossible if you’re trying to hold an angle grinder to a chisel by hand.
-- Greg, Severn MD
View Roper's profile
Roper
1333 posts in 1878 days
#6 posted 953 days ago
This is not an ax, you do NOT sharpen a chisel on an angle grinder,first it is not safe, second how will you be able to hold a bevel, third the angle grinder is going to heat up the steel of the chisels which is bad for them. Just buy a set of stones and learn how to put a nice edge on by hand.
-- Roper - Master of sawdust-www.coloradocustomworks.com
View Benighted's profile
Benighted
57 posts in 1027 days
#7 posted 953 days ago
The hardened metal in chisels and other cutting tools loose the correct hardening and molecular structure when heated (and in carbon steel, the carbon becomes “denatured”, which is a irreversible reaction), so it’s a bad idea for your tools (and possibly your health) to use a angle grinder on them.
-- Jani, a Neanderthal woodworker in Sweden.
View richgreer's profile
richgreer
4474 posts in 1240 days
#8 posted 952 days ago
I’ll join the chorus. Sharpening with an angle grinder – - not a good idea.
newbiewoodworker
#9 posted 952 days ago
I did it… Unfortunately I was out for a class extra credit assignment, when you guys wrote these… All I can say… Is I am glad they were cheapos…
I also learned that when something feels hot in the hand that has a leather glove on it… its not a good idea to pick it up with the hand that has a light weight nylon glove on it… the bandage on my finger is now fused to it…..
I am just now sharpening them up to use as real beaters… such as prybar and screw driver uses…
Not to mention they will work well for learning to sharpen them…
The remainder of my method is the Scary Sharp™ method… 4 grits of sandpaper: 200, 400, 600, 1000, glued to a piece of plexi… HD didnt carry plate glass.. plus it was only $4 for a piece a little bigger than a sheet of printer paper… and about 1/16-3/32 thick…
As for the safety… its remarkably safe, using a flap wheel. I was worried about a AO disk fragmenting, so that influenced the decision… And because the guard is bent(I dropped the grinder… opps) I had to take it off to use a screw on… even more reason…
But what I hate… is when ever I grind, I end up blowing black snot for the rest of the week… and having that metallic taste occasionally…
Sawdust: I dont hold the grinder… I put the grinder on my planer table(I covered everything with plastic, since I didnt want metal in my machine.. or in the wood…) I then stablize it with one hand, while holding the chisel in the other…
View swirt's profile
swirt
1864 posts in 1137 days
#10 posted 952 days ago
Hardened steel for a prybar??? an accident waiting to happen.
Sharpening on 1/16” plexiglass?.... too flexible to stay flat unless you put it on top of something solid like a table saw.
A loose angle grinder held on top of a planer tabler???
I get the feeling you are pulling our legs to be funny.
newbiewoodworker
#11 posted 952 days ago
Well then, your feelings are incorrect. That is how I did it. And it works fine. I do put the plexi ontop of my workbench, I just used it as something to hold down the paper/ minimize bumps…
Yea.. the pry bar idea was just a joke… I know thats not exactly a good idea.. lol
View Howie's profile
Howie
2448 posts in 1088 days
#12 posted 952 days ago
I’d find another shop teacher.
-- Don't rollerskate in a buffalo herd
View hairy's profile
hairy
1763 posts in 1698 days
#13 posted 952 days ago
I use one of these: http://www.leevalley.com/US/wood/page.aspx?p=60311&cat=1,43072,43078&ap=1
I use it on a coarse oil stone to set the angle, then a fine water stone to sharpen. The first time takes a while, after that it’s easy. You will need to make a jig to set the proper angle, but that’s easy. I’ll post a pic if needed.
-- It must be jelly baby, cause jam don't shake like that...
Howie
#14 posted 951 days ago
After rereading this..”.not so concerned with safety” You should always be concerned with safety. If something happens and that grinder gets loose you are seriously injured before you know it. Your shop teacher should have pounded this into peoples heads. Safety first is not a joke. You might get by sometimes but it usually catches up with you.
newbiewoodworker
#15 posted 951 days ago
You mis-interpreted what I meant… I still have a hand on the grinder.. its just resting on the table.. but with a firm enough grip.. I also grind on the side thats coming toward me, not away..
Believe me… I let myself get careless, resulting in one of my leather gloves(old winter ones) getting a nice hole burned right through 90% of the layers…
