Need to remove plugs
Forum topic by McFly posted 03-08-2017 04:22 PM 650 views 0 times favorited 13 replies Add to Favorites Watch
View McFly's profile
McFly
273 posts in 1175 days
03-08-2017 04:22 PM
Outdoor bench pulled itself apart, so I’ll need to break it down and rebuild it. Only problem is that I covered the screw holes with plugs.
Anyone have a tip/trick for removing glued in plugs covering screws?
13 replies so far
View johnstoneb's profile
johnstoneb
3014 posts in 2321 days
#1 posted 03-08-2017 04:29 PM
Drill them out.
-- Bruce, Boise, ID
View jimintx's profile
jimintx
836 posts in 1733 days
#2 posted 03-08-2017 04:34 PM
Huh, well – I would drill them out. I suspect you can drill with care, and remove just enough to be able to access the screws without risking damage to the screw heads. If the first one fails badly, then I would have to stop and think of what to try next.
I’d start with a very small drill, and then advance to larger ones, incrementally, until the plug comes loose.
-- Jim, Houston, TX
View bigblockyeti's profile
bigblockyeti
5229 posts in 1869 days
#3 posted 03-08-2017 04:35 PM
A slide hammer with a screw point would work well. Are they just pounded in or glued as well?
Smitty_Cabinetshop
15582 posts in 2767 days
#4 posted 03-08-2017 04:37 PM
Center point drill bit, the right size and one that gets this single use (it’s gonna hit the head of the inset screws and suffer as a result, but it should work for task).
View crank49's profile
crank49
4032 posts in 3119 days
#5 posted 03-08-2017 04:42 PM
Use a left hand, HSS drill bit to drill out the plug then engage the screw head and back the screw out.
McFly
#6 posted 03-08-2017 05:03 PM
- bigblockyeti
Screwed and glued. But not blued or tattooed
McFly
#7 posted 03-08-2017 05:05 PM
Looks like I’ll have to sacrifice a drill bit on this one.
View mike02130's profile
mike02130
170 posts in 821 days
#8 posted 03-08-2017 07:13 PM
Use a regular HSS drill bit. Plug will break out before you damage the screw head. You can also drive a largeish screw into the plug.
-- Google first, search forums second, ask questions later.
View bondogaposis's profile
bondogaposis
4996 posts in 2499 days
#9 posted 03-08-2017 07:21 PM
I just take an ordinary screw and drive it into the center of the plug, when the screw bottoms out, the plug will pop out.
-- Bondo Gaposis
View putty's profile
putty
1208 posts in 1755 days
#10 posted 03-08-2017 07:59 PM
Drive a flat head screwdriver in then just pop it out. That’s how it is done with wooden boats.
-- Putty
View bonesbr549's profile
bonesbr549
1576 posts in 3215 days
#11 posted 03-08-2017 08:45 PM
Ok depending on how well you glued in (I tend to over achieve), A good solution I’ve used in this is a set of plug cutters. Just go one size bigger than the plug drill down and you won’t damage the screw head. You can then get it out and do over.
If not drill it out and use an ez-extractor bit to get the screw out.
I have both these and they come in handy!
http://www.toolnut.com/snappy-43300-plug-cutter-set.html?utm_source=google_shopping&gclid=Cj0KEQiA9P7FBRCtoO33_LGUtPQBEiQAU_tBgANL77oHvX_jcolyJQQWBo8DSxwvFSmRyCFItb-CvQUaAuAO8P8HAQ
https://www.amazon.com/Extractor-Aisxle-Stripped-Hardness-62-63hrc/dp/B01CA1PSCQ/ref=sr_1_1?ie=UTF8&qid=1489005889&sr=8-1&keywords=ez+out+screw+extractor
View Bobmedic's profile
Bobmedic
381 posts in 2950 days
#12 posted 03-08-2017 09:56 PM
Sacrifice a Kreg bit. Grind the pilot tip off and position the guide block over the plug and clamp it down. Drill slowly until you get to the screw.
View TheFridge's profile (online now)
TheFridge
10353 posts in 1634 days
#13 posted 03-08-2017 10:11 PM
- bondogaposis
Ditto
