misaligned bandsaw wheels, ok/not ok?
Forum topic by BANick posted 10-08-2010 08:41 AM 1624 views 0 times favorited 8 replies Add to Favorites Watch
View BANick's profile
BANick
53 posts in 3850 days
10-08-2010 08:41 AM
I just received a powermatic 14” bandsaw, with the riser block. The wheels were coplanar without the riser block but after installing it, they are parallel but the two planes are off by about 1/16”.
This amount of misalignment seems pretty small to me but I don’t have experience tuning a bandsaw, so what do you think? leave it as is or get it aligned properly?
Nick
-- Nick, Fremont, CA.
8 replies so far
View olddutchman's profile
olddutchman
187 posts in 3898 days
#1 posted 10-08-2010 11:23 AM
I think that I would see the results first. check the saw in running mode, and if You can, use an old blade,or a cheap blade. You know whats wrong, and I don’t think it would be hard to align, It seems that it is probably near or within tolerances
-- Saved, and so grateful, consider who Created it ALL!!!
6851 posts in 3942 days
#2 posted 10-08-2010 07:40 PM
Hi Nick;
I’m not certain if this will cause you any problems, since it’s been quite a long time since I did any band saw tune ups.
It seems to me that you can add a washer behind the wheel to get them coplaner.
But as mentioned, it’s been so long, I couldn’t swear to it.
View ajosephg's profile
ajosephg
1880 posts in 3524 days
#3 posted 10-08-2010 07:58 PM
If the blade stays on, why not leave it be?
-- Joe
View TheDane's profile
TheDane
5399 posts in 3626 days
#4 posted 10-08-2010 08:00 PM
I would try to get them properly aligned. As I recall, the tires are actually crowned a bit, which means the blade isn’t running correctly unless the wheels are co-planar.
Does it cut straight?
View newbiewoodworker's profile
newbiewoodworker
668 posts in 2790 days
#5 posted 10-08-2010 09:15 PM
Check for a washer/shim behind the top wheel. If its out 1/16 in, remove it… if its back 1/16in add one…
-- "Ah, So your not really a newbie, but a I betterbie."
BANick
#6 posted 10-08-2010 09:33 PM
OK, thanks all for your feedback, I’ll try shimming the wheel.
View mcase's profile
mcase
446 posts in 3092 days
#7 posted 10-09-2010 02:24 AM
BANICK,
I had the exact same issue with my Powermatic 14”. Mine was even more misaligned. I went to a lot of trouble shimming it and fussing around with all that Gary Rogowski coplaner crap. It would not cut right. Finally after a lot of needless work and frustration I set it up just the way the manufacturer had it. I then simply tuned it as one would any band saw. THEN it worked great and still does. The saw has crowned wheels. Coplaner makes a big difference with flat wheels but is not that important within in reasonable limits with crowned wheels. Before messing around, set it up and tune it carefully. You may find that you have a decent saw that needs no more adaptations and will work better without them.
BANick
#8 posted 10-18-2010 09:54 PM
mcase,
I finally got the time to work on this. I finished putting it together over the weekend without shimming or anything else, and it seems to work just fine. Thanks for your input and perspective, unless it starts acting up later, I don’t see the need to mess with it at this point.
