Nailer will not work with 1" nails
Forum topic by Cal2 posted 03-08-2017 02:32 AM 521 views 0 times favorited 6 replies Add to Favorites Watch
View Cal2's profile
Cal2
2 posts in 467 days
03-08-2017 02:32 AM
Topic tags/keywords: question nail gun
I have a Porter Cable 16 Gauge nail gun.
It operates perfectly when using the Porter Cable 2” and 1.5” nails but will not work with the Porter Cable 1” nails.
I install the adapter that is needed for the small size nails but most of the time nothing comes out when I try to nail (a nail will come out very infrequently). The plunger does make an indentation in the wood but there is no nail there. I have tried raising the air pressure from 60psi in increments of 10 up to 100psi with no effect.
There are no air leaks.
Can anyone help me before I have to go buy a new nailer?
18351 posts in 1878 days
#1 posted 03-08-2017 02:45 AM
I’ve never heard of this adapter. You’re using 16g nails?
View pintodeluxe's profile
pintodeluxe
5701 posts in 2835 days
#2 posted 03-08-2017 03:34 AM
I always use mine without the adapter and never had any issues. Make sure the nails are all the way forward in the magazine.
View Kirk650's profile
Kirk650
525 posts in 770 days
#3 posted 03-08-2017 03:43 AM
I’ve had that problem with my 16 ga nailer. I lightly oiled the area where the nails feed toward the head, and all was fine. I’ve had to do it a couple of times over a year or so.
View GR8HUNTER's profile
GR8HUNTER
3993 posts in 734 days
#4 posted 03-08-2017 03:45 AM
check make sure the nails are loaded right ..so head is just above the groove …so they feed …sounds like they are getting caught on the lip there ….GOOD LUCK :<))
View Cal2's profile
Cal2
2 posts in 467 days
#5 posted 03-08-2017 03:41 PM
Thanks for all the suggestions.
Yes, I am using the Porter Cable 16 gauge 1” nails and according to the gun’s instructions the adapter must be used for any nails smaller than 1.5”.
I will try the oil trick and see if that helps (I haven’t oiled it in quite awhile).
Thanks again.
View Dee1's profile
Dee1
296 posts in 1911 days
#6 posted 03-08-2017 04:25 PM
Are you sure you have the adapter in properly?
I have the same gun and it works great? when installed right?
