Bandsaw Help
Forum topic by RickM posted 297 days ago 301 views 0 times favorited 4 replies Add to Favorites
View RickM's profile
RickM
27 posts in 299 days
297 days ago
Topic tags/keywords: question bandsaw
Okay first I am sensitive (LOL) so be gentle, I have a very small home shop – sharing a small one car garage with a hot water heater, 6 1/2 HP 60 gal compressor, washer, and dryer. Don’t laugh at me but I own a Shopsmith MK V 510, and while I wish I had stand alone tools my space is just not sufficient though I do have a radial arm saw, mitre saw, and a planer. The problem I am having is with the bandsaw and though I can ask this at Shopsmith I am considering purchasing a Grizzly 14” Bandsaw and so I want the opinions of others that do not have Shopsmith on the brain. I watch a lot of woodworking shows on the web and TV and notice them using 1/4” blades (and sometimes larger) and creating intricate curves and circles, on my saw I can not cut less the a 4” curve with a 1/4” blade without it screaming and throwing sparks from the cool blocks. So am seeing things on these shows or is the Shopsmith bandsaw a proverbial POS and I should just plan on scraping it?
-- RickM
View TonyWard's profile
TonyWard
162 posts in 856 days
297 days ago
RickM
A 1/4” blade will bandsaw a 5/8” circle. If your bandsaw can’t do that then it is a question of set up. Here is a reference for blade sizes and the minimum radii ~ http://www.allbandsawblades.com/Images/radius_chart.gif, the site also has a number of other very useful references.
If you run out of information there, then use this reference list ~ Bandsaws and Blades information sites
Don’t forget when your bandsaw is operating properly you can have fun making Bandsawn Boxes Bandsawn Box Plans
Good Health
Tony Ward
-- Bandsaw Box Plans
View markrules's profile
markrules
134 posts in 643 days
297 days ago
Band saw blades cut curves by cutting a wider kerf than the blade itself, and by sliding the back of the blade inside that kerf. If your blade won’t cut curves, you could very well have a blade without any set left. If the blade is setting too far back in the guides, the blocks will knock the set out (probably sparking as it does this).
A new blade, and a reset backup guide might just fix your sawing problems.
-Mark
View Thos. Angle's profile
Thos. Angle
3409 posts in 490 days
297 days ago
All the above plus maybe not enough tension. I still have my ShopSmith but sold the band saw and other accessories. I think you should try a new blade and check the set up. That saw will cut very well.
RickM
297 days ago
Mark – thanks shows how much I know, I was under the impression that since the cool blocks were softer than the blade that they could actually envelop the entire blade providing more support and to keep the blade from angling in the wood which was one of the other problems.
Thos you are right about the tension as well since the bandsaw uses a proprietary 72” blade I was using a 72 7/16” Vermont American blade which is only a 1/16th under the maximum and was not able to get the blade tight enough. I will be having custom blades made at Cal-Ore Carbide from now on. In you opinion since you have had both how would you rate the Shopsmith Bandsaw up to say a Grizzly?
-- RickM
Bookmark And Share This Page
