raised panel cabinet doors
« back to Joinery forum
Forum topic by stripit posted 03-07-2017 10:04 PM 789 views 0 times favorited 6 replies Add to Favorites Watch
View stripit's profile
stripit
25 posts in 2100 days
03-07-2017 10:04 PM
Topic tags/keywords: doors raised panel kitchen
Hi. I need to make 4 rasied panel doors for the base unit for shelves in our new kitchen. I’m looking for a router bit set, (3 piece) to make them witth. the panels we have are 5/8” thick and have a 1” bevel showing. All the sets I have seen are ogee or somthing like that not a bevel, and are for 3/4” thick wood. Any suggestions would be most welcome.
Thanks Joel
View scribble's profile
scribble
195 posts in 2257 days
#1 posted 03-07-2017 10:08 PM
I believe you may find what you are looking for at precision bits. I have not tried there bits yet but they do have a lot of different designs.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
View TungOil's profile
TungOil
979 posts in 551 days
#2 posted 03-07-2017 10:21 PM
I believe the MLCS bits will work with 5/8” or 3/4” panels.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View pontic's profile
pontic
615 posts in 665 days
#3 posted 03-07-2017 10:39 PM
Yes either source is good and will get you what you need.
-- Illigitimii non carburundum sum
View jerryminer's profile
jerryminer
937 posts in 1498 days
#4 posted 03-09-2017 12:05 AM
Something like the Infinity 90-502?
jerryminer
#5 posted 03-09-2017 12:26 AM
Or… if you want a simple bevel profile, you can cut that on the table saw with a tall fence.
View Madmark2's profile
Madmark2
379 posts in 644 days
#6 posted 03-09-2017 12:27 AM
Any panel raising bit can be used for either 5/8” or 3/4” as you are routing face side down.
The rail and stile bits are a bit fussier and generally set to 3/4”.
M
