Can anyone explain this tabletop to me?
Forum topic by Derrick posted 03-07-2017 09:58 PM 483 views 0 times favorited 4 replies Add to Favorites Watch
View Derrick's profile
84 posts in 1071 days
03-07-2017 09:58 PM
Until recently I thought that a butterfly leaf dining table would be perfect for our house. Then someone posted a draw leaf/Dutch pullout over here, and now I’m torn between the two. Anyhow, I’m not sure where I found this one, but I love the design. I’m confused about the tabletop though. I’ve seen bow ties used in plenty of projects. I even have a couple of threads saved where members talk more indepth about them. The problem is, the ones I’ve seen have been used for stopping splits in the wood from traveling. This table top seems to be using them to hold the table top together, and also allowing for movement. They’re all evenly spaced, and are spread out over the entire top. Would that be a feasible way of doing things, or would something like this be more of a decorative thing, and the person would still glue the boards long grain to long grain?
Thank you.
View TungOil's profile
870 posts in 428 days
#1 posted 03-07-2017 10:31 PM
I like the design also. I’d be 99% sure those particular butterfly’s are decorative only. They are not needed for a glue up like that and not every board in the top has them.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View AandCstyle's profile
3004 posts in 2190 days
#2 posted 03-07-2017 10:41 PM
Derrick, I am going to guess that these butterflies are only decorative veneer. Otherwise, they would attempt restrict the movement of the top. Glue the boards for the top together as normal. FWIW
-- Art
View TheFridge's profile
9088 posts in 1419 days
#3 posted 03-07-2017 10:44 PM
Decorative only
#4 posted 03-07-2017 11:44 PM
Well, I guess I was completely fooled by decoration. Thank you for the help!
