Boiled Linseed Oil
Forum topic by Fax posted 03-07-2017 08:34 PM 1234 views 0 times favorited 13 replies Add to Favorites Watch
View Fax's profile
Fax
62 posts in 481 days
03-07-2017 08:34 PM
I applied Boiled Linseed Oil on a pine chair.
I made a mistake. I wish I didn’t do it.
I just found out that it takes at least 3 days before I can apply a topcoat. I would like to appy a stain and then polyurethane.
Could I wipe any residue with Denatured Alcohol, Lacquer Thinner, or Paint Strippers and start over right away? I thank you very much for your advice and help!
Julian
-- Julian Paul Jones
13 replies so far
View johnstoneb's profile
johnstoneb
2938 posts in 2197 days
#1 posted 03-07-2017 08:51 PM
You can wipe it with lacquer thinner or mineral spirits and it may speed the drying up. It won’t hurt it even if it doesn’t speed things up.
-- Bruce, Boise, ID
View Fax's profile
Fax
#2 posted 03-07-2017 09:09 PM
Thank you very much Bruce!
I wiped it thoroughly this morning right after I applied it. It is not wet or tacky buildup on top.
When I get home I will follow your advice.
Could I apply stain afterwards and tomorrow polyurethane?
Should I seal it with dewaxed shellac before polyurethane?
I really appreciate your help here. I promised my wife to finish it before the weekend.
Julian
4999 posts in 2517 days
#3 posted 03-07-2017 09:26 PM
Actually with an oil based finish you could top coat it the next day (the BLO, if it was applied, allowed to sit a few minutes, and then wiped off). But if using a waterborne, it should sit maybe as long as a week. You can apply the stain if it’s oil based and maybe top coat it tomorrow. Many of them have a linseed oil base, so you have 2 coats waiting to cure slightly. I wouldn’t put a waterborne stain on it that soon. So, you can stain it, follow the directions on the can (for the stain) on how long it takes…typically ovenight is good. But before you try to op coat it, check it to see it has set up.
View Fax's profile
Fax
#4 posted 03-07-2017 09:41 PM
Thank you so much Fred!
WONDERFUL NEWS! I am so glad now. Yes, I will use oil based stain.
Thank you so much for your help! I was so upset because I thought that I have to wait at least a week to apply a topcoat. Now after I get home from work I will apply the stain and tomorrow the polyurethane.
Again, thank you very much !
Julian
View pontic's profile
pontic
591 posts in 632 days
#5 posted 03-07-2017 10:50 PM
I don’t care what others say Polyurethane does not penetrate. So just wipe until excess is removed and put on poly.
-- Illigitimii non carburundum sum
View tomsteve's profile
tomsteve
790 posts in 1243 days
#6 posted 03-08-2017 01:08 AM
I don t care what others say Polyurethane does not penetrate. So just wipe until excess is removed and put on poly.
- pontic
if poly doesnt penetrate, than can you explain why,when i wipe on gloss poly, i dont have a gloss finish evenly until at least the 3rd coat? seems if poly didnt penetrate, the no other oil based product would. so stain would just sit on top. seems if poly didnt penetrate then i wouldnt be able to watch it soak into end grain. seems if it didnt penetrate….oh heck,
i already know the truth.
View Woodknack's profile
Woodknack
11774 posts in 2404 days
#7 posted 03-08-2017 02:48 AM
You can also seal it with shellac, which is not at all bothered by oil.
View Fax's profile
Fax
#8 posted 03-08-2017 05:28 PM
Thank you very much for all your help!
I am very grateful for your kindness.
Julian
pontic
#9 posted 03-09-2017 09:48 PM
Poly Shrinks on setting and sets to itself. wait until you get a deep scratch on that 3 coat or 5 coat finish and see if oil and other stuff doesn’t seep under the layers.
pontic
#10 posted 03-10-2017 01:00 PM
The oil penetrates but the polymer not so much. Each additional coat just lays on the surface like a bedspread.
View Andybb's profile
Andybb
1017 posts in 627 days
#11 posted 03-11-2017 06:06 AM
- Rick M
+1
-- Andy - Seattle USA
View mummykicks's profile
mummykicks
109 posts in 1826 days
#12 posted 03-14-2017 07:50 PM
- Rick M
+1
- Andybb
+2. A couple quick coats of shellac, then paste wax.
mummykicks
#13 posted 03-14-2017 09:13 PM
- Rick M
+1
- Andybb
