Porter Cable 15" drill press question
Forum topic by Woodman348 posted 03-07-2017 01:53 PM 537 views 0 times favorited 3 replies Add to Favorites Watch
View Woodman348's profile
Woodman348
3 posts in 683 days
03-07-2017 01:53 PM
Topic tags/keywords: question jig
I need to build an auxiliary table for my Porter Cable 15” drill press. I want to be able to secure the base for a auxiliary table with bolts that slide through the slots in table. What kind of bolt would have a head large enough to catch the sides of the slots to keep it from turning with the nut which would be in the countersunk holes on top base. This is the way Id really like to mount it since I don’t want to drill holes through the original table.
3 replies so far
View HokieKen's profile
HokieKen
7530 posts in 1374 days
#1 posted 03-07-2017 03:23 PM
I don’t know what size the slots are but, there are several options. Carriage bolts have a square section below the head that would need to be the same size as the small part of the slot. If you have 1/2” slots, get a 1/2” carriage bolt. There are also closet bolts and curved head bolts in smaller sizes that may work to grab in the wider portion of the slot. If nothing else, you can get a carriage bolt or flanged-head bolt that’s bigger than the wider portion of the slot and grind flats on 2 sides. There are several options. Measure your slots and take the measurements to the hardware store and you’ll find something that will work. Or, if you want, post the measurements here and I’ll throw out some specific suggestions.
Welcome to Lumberjocks!
-- Kenny, SW VA, Go Hokies!!!
View scribble's profile
scribble
204 posts in 2436 days
#2 posted 03-07-2017 04:26 PM
I have the same press and I made a top plate with countersunk holes to bolt the top to some T-nuts that I purchased from McMaster car that fit the slots in the table. I also did a clamp style that encased the table and then used the red toggle clamps to hold to securely.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
Woodman348
3 posts in 683 days
#3 posted 03-07-2017 07:38 PM
Thanks. I just got back from Lowes with some T-nuts which I’ll mount in small strips of oak in the slot. That should work.
