| Forum topic by Coleby | posted 961 days ago | 8352 views | 2 times favorited | 18 replies | ![]() |
961 days ago |
I really need some advice on staining maple. I just finished an entertainment center built out of maple and birch ply. I only discovered the difficulties of staining these woods after the fact. I want a dark color that wont appear black when I finish. Just a standard darker color like cherry or something similar. Please help! thanks, -- Dean, http://www.woodworkerColeby.com |
18 replies so far
#1 posted 961 days ago |
It almost sounds like you’ve discovered the difficulties be staining it already, but assuming that’s not so, I’d practice with some stains on scrap pieces the check for the results you want. Also, you might want to consider giving it a coat of Zinsser’s sanding sealer & lightly sanding or steel wooling it before staining to help prevent blotchiness. But always practice first on scrap. You might want to try a couple of colors of gel stain to see if you like the way it applies. -SST -- Accuracy is not in your power tool, it's in you |
#2 posted 961 days ago |
Maple is hard & dense, so the relatively large pigment particles can’t penetrate the wood very well. They even highlight the sanding scratches. Try some dyes instead, like TransTint, a concentrated dye that you mix with water. -- "Heaven is North of the Bridge" |
#3 posted 961 days ago |
Why would you use maple if you want a dark finished product? I don’t understand. If you want figure, that’s OK. But you’ll have to use a sealer if you want some sort of “uniform” finish on maple. And, like 8iowa says, dye’s a better bet…but only if you want “pop”. |
#4 posted 961 days ago |
Both your woods are notorious for blotching. Minwax makes a product for this: Minwax Pre-Stain wood conditioner. paste from the MW site: Application tool: cloth or brush end paste. I have used it but not with astonishing success. It was an improvement over not using it. -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#5 posted 961 days ago |
I have had success using a dye as mentioned above and then put a spit coat of shellac over that, then when dry a light sanding with 0000 steel wool or a buffing pad (gray). Then apply a coat of Gel stain to get the color and tone you want. Hope this helps. -- Max "Desperado", Salt Lake City, UT |
#6 posted 961 days ago |
Two parts to this post. First; Preventing this in the future. 1. Moisten maple with damp cloth, you’re only looking to raise the grain not force enough water in to warp the wood Second, dealing with the situation of a blotchy entertainment center sitting in your shop If you have time you can strip the surface using a dichloromethane based stain/varnish stripper. Please note, it is very caustic, will cause a first degree chemical burn if applied to skin. Wear gloves, wear goggles, work with plenty of fresh air. For the solid wood parts an alternative is to sand, but on ply parts you’ll have to be careful. Once you’ve removed the stain you can go ahead with a coloring/finishing routine If you’re “out of time” on the project then you’ll have to use a tinted shellac/glaze method that will obscure the grain. You’re looking to create a smooth finish by applying full strength tinted shellac and glaze coat. Stick with dewaxed to avoid topcoat problems, and apply enough coats to hide the blotchiness. Best of luck |
#7 posted 961 days ago |
Thank you everyone! Atomjack, I really did not plan on staining this piece dark to start with. I thought about some sort of clear coat but my wife changed her mind and thought it would better match our den with a darker color. Everyone’s advice has been very helpful. I will try a few such as the dyes and gel stain with of course the prestain before going through with anything. Thanks! -- Dean, http://www.woodworkerColeby.com |
#8 posted 960 days ago |
I use dye stains from Mohawk or Behlen or M L Campbell has stains that will wipe and or spray well. I have found these methods produce the best clarity with no blotching. No mixing or sealer coats before staining. Good for toning uneven color also. The reason to choose maple and stain it dark is that it is a wood that is relatively cheap with nice tight grain features that can be made to look like a variety of woods. |
#9 posted 960 days ago |
The only thing I would add to the above is about the min-wax stain conditioner. I have had much better luck letting it dry overnight. Then wipe with a rag damp with mineral spirits. If an area soaks in/dries much more quickly than the surrounding area, coat that area again and repeat the overnight dry. The “soak in” area is where you will have a darker blotch in your stain. When it is even, then lightly scuff sand before applying your stain. If the stain will not penetrate, use a higher grit sandpaper with a block and with the grain. The more porous wood should still stay sealed unless you over-sand. The spirits wipe also will work with the Zinsser, (overnight dry not needed) altho I have not tried the cutting the 2# mix to 1#, which I will in the future. Thank you Nathan Allen for the tip. Go -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
#10 posted 960 days ago |
Gofor, exactly, technically we should be using flakes, but having dewaxed #2 that can be cut to #1 and sit on the shelf about a year is too convienent. And thank you for the tip on Minwax, I’ve avoided staining maple because I could never get the samples right even with conditioner, but mineral spirits should help identify those spots. |
#11 posted 953 days ago |
I am sure by now you have decided on a process, but I thought I would throw this out. I use Seal Coat cut 50/50 with alcohol as NathanAllen described. I, however, favor gel stains for these types of hard to stain woods especially if trying for a dark color. I have had really good success with them. The General Finish products seem to work the best for me but I have used other brands with good results too. Charles Neil also sells a water based product that does a great job as a seal coat. Using it or using the shellac method described above I have been able to get excellent looking results using pine and popular in addition to maple. -- Ron, Kutztown, PA "The reward is in the journey." |
#12 posted 949 days ago |
Ron thanks for the advice! Do you have a recommendation for which general finish gel stain to use. I was thinking the antique walnut but I want a dark color but not so dark it looks black! I want to see the grain patterns and bring out my work. Let me know if you have a suggestion. Thanks! -- Dean, http://www.woodworkerColeby.com |
#13 posted 948 days ago |
I did a recent project out of maple ply and had no problem with any blotching on the plywood (the solid hard maple is another story for a different time). I used minwax pre stain conditioner with minwax red mahogany oil based stain. It is my only project posted on here but you cant really see the plywood. All you can see is the solid drawer fronts and they turned out horribly blotchy but it was because of my own error. I had no blotching what so ever on the plywood using this method though and the grain pattern shows pretty well also. |
#14 posted 948 days ago |
Dean, For the table I think I used GF Candlelight but my wife wanted it still darker so I used another shellac wash coat followed with a final coat of GF Java which is really dark which is why I used the wash coat in between. The table is on my project page if you want to have a look. -- Ron, Kutztown, PA "The reward is in the journey." |
#15 posted 948 days ago |
Just my two cents … I vote for Zinsser over Minwax. -- http://www.peteroxley.com -- http://north40studios.etsy.com -- |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15815 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6166 |
