DeWalt 13" planer
Forum topic by Stanley Coker posted 03-07-2017 12:21 AM 713 views 0 times favorited 5 replies Add to Favorites Watch
View Stanley Coker's profile
Stanley Coker
243 posts in 3098 days
03-07-2017 12:21 AM
Topic tags/keywords: planer question
Hi all, just wanted to know if anyone else has had the problem that I have with my DeWalt DW735 planer. The power switch burned out a while back and I finally took it to my work and the electrician put another switch on the planer. I finally got it back in my shop to do some planing, when I turn the handle to raise and lower the cutter head, it is all I can do to turn the handle. I took the cover off and cleaned out all the wood chips around the chain that goes around all the four corner post and check everything I could think of, but it still is very hard to turn. It is like something is in a bind, but I can find nothing. I have a Ridgid planer that I can use but would really like to use the DeWalt.
-- Stanley, North Georgia
5 replies so far
View Sawdust2012's profile
Sawdust2012
112 posts in 1615 days
#1 posted 03-07-2017 12:51 AM
Not to insult your intelligence, but only because I have done this, is the lock bar down?
View greenacres2's profile
greenacres2
313 posts in 2070 days
#2 posted 03-07-2017 02:01 AM
No lock bar on the 735 (like there is on the 733 and 734). Might want to check the depth stop wheel to see if it is set thick (and you’re trying to lower) or if it may have gotten hung up on the stop bolt inside.
earl
View TheFridge's profile (online now)
TheFridge
8847 posts in 1389 days
#3 posted 03-07-2017 02:08 AM
I think it has an automatic cutterhead lock.
View Carloz's profile
Carloz
1147 posts in 494 days
#4 posted 03-07-2017 06:26 AM
Piece of wood on the table ?
View skipj's profile
skipj
96 posts in 2175 days
#5 posted 03-07-2017 12:10 PM
Take the cover off again,also the dust shroud and look close at the sprockets the chain goes around.
If very fine sawdust is cacked just under the chain,look close at the left rear sprocket.If this is the problem
the dust shroud is leaking. Replace the rubber striping under the shroud with 3/8 X 1/4 weather striping.
