Kinked Bandsaw Blade, Any Fix?
Forum topic by Ripthorn posted 10-06-2010 07:59 PM 1793 views 0 times favorited 8 replies Add to Favorites Watch
View Ripthorn's profile
Ripthorn
1459 posts in 3223 days
10-06-2010 07:59 PM
I have a relatively new Grizzly 1/4” 6 TPI blade on my bandsaw. I was cutting some 2” thick basswood and all of a sudden the saw made some noise and the cut quality really tanked. I took a careful look at the blade and it turns out the blade kinked a little in one spot. This means the blade travels smoothly except where the kink goes on and off the wheel and the kerf is now wider because of the kink. Is there any way to fix this, or do I need a new blade? I tried taking some pliers to it, but to no real avail. Thanks for any input.
8 replies so far
View interpim's profile
interpim
1170 posts in 3696 days
#1 posted 10-06-2010 08:04 PM
I’ve had that happen, and I’ve never found a way to fix it… I have the blade saved for doing rough cuts if I need it, but for the most part blades are cheap so I bought a new one.
-- San Diego, CA
Rick Dennington
6349 posts in 3432 days
#2 posted 10-06-2010 08:13 PM
Greetings Ripthorn,
I’d say s.c that blade and get you some GOOD saw blades…...Those blades they put on at the factory are
cheap-made and of low quality… They just won’t hold up long, as you found out….Get yourself a couple of
Timberwolfs, or good blades along that line…..You’ll be glad you did…..
-- " At my age, happy hour is a crap and a nap".....!!
View TheDane's profile
TheDane
5575 posts in 3901 days
#3 posted 10-06-2010 08:28 PM
I’m with Rick and Dahlgren … you could try to take the kink out (with a hammer on an anvil), but all you’ll wind up with is a low-quality blade that has been weakened and may be dangerous. Most of the time when a blade breaks it just sounds like a corn sheller, but you could wind up injuring your hands, etc.
Personally, I am a fan of the Wood Slicer blades (from Highland Woodworking in Atlanta), but Timberwolf gets a lot of good reviews. Either is better than the blade your saw came with.
View lwllms's profile
lwllms
555 posts in 3519 days
#4 posted 10-06-2010 08:29 PM
Throw the blade away. When a bandsaw blade breaks it can jump out under the table and into your body. I have a cousin with severe brain damage after this happened to him severing an artery in his leg and it taking too long for anyone to come to help.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4365 days
#5 posted 10-06-2010 09:03 PM
Time to make a frame saw with the wasted blade. :)
-- 温故知新
View Gregn's profile
Gregn
1642 posts in 3221 days
#6 posted 10-07-2010 02:32 PM
You could cut it and reweld the joint but this would make the blade to small unless you have room for readjustment. If you don’t have a band saw blade welder you would be cheaper off getting a new one. This the only way I know to safely repair a kinked blade.
View richgreer's profile
richgreer
4541 posts in 3312 days
#7 posted 10-07-2010 08:56 PM
Don’t mess around with a kinked blade. There are some good uses for used BS blades.
View newbiewoodworker's profile
newbiewoodworker
668 posts in 3065 days
#8 posted 10-07-2010 10:03 PM
I am thinking of turning my 14 tpi blade, that rusted, that I felt had become unsafe due to the oxidization, into a bow saw… its still sharp enough to cut flesh… so I imagine it will work for wood. I ended up breaking it, when I pulled it out of the trash can, since I was thinking of using it for one brief job… I nicked my hand pretty good…
You might think of doing that yourself(the bow saw part… not the cutting your hand part…)
-- "Ah, So your not really a newbie, but a I betterbie."
