installing metal hooks for bed rails
Forum topic by bluephi1914 posted 03-06-2017 04:14 AM 1185 views 0 times favorited 9 replies Add to Favorites Watch
View bluephi1914's profile
bluephi1914
64 posts in 1233 days
03-06-2017 04:14 AM
Does anyone know what is used to cut the slot that the hooks slide into ?
im replacing side rails that were cracked and around the hook area and i would like to know how to cut this slot in the wood.
-- Jack of all trades and a master of most of them.
9 replies so far
View bandit571's profile
bandit571
18933 posts in 2558 days
#1 posted 03-06-2017 05:24 AM
Last time I did a set of these…I used a circular saw. Plunge cut. Clamp a 2×4 on each side to keep the saw level, and set the saw to the depth you need.
View dhazelton's profile
dhazelton
2657 posts in 2172 days
#2 posted 03-06-2017 02:02 PM
^ That was my thought. Put support on the sides to keep your sole plate flat. Or if your table saw blade goes high enough you could use that.
View Lazyman's profile
Lazyman
1565 posts in 1262 days
#3 posted 03-06-2017 04:22 PM
I think that the brackets like that you can buy at Rockler show them surface mounted rather than set inside a slot.
View ShaneA's profile
ShaneA
6879 posts in 2473 days
#4 posted 03-06-2017 04:46 PM
Pictures of the specific hardware in question would be helpful. I am assuming these “hooks” mate into the post, and not the rail?
Edit: I see the pics now.
View RichCMD's profile
RichCMD
391 posts in 1816 days
#5 posted 03-06-2017 05:07 PM
I was recently faced with the same problem. After experimenting a bit, I could not find a way to cut the slots that I felt was safe. Instead, I used a second piece of wood as a covering block at the end of each rail. This covering block was about 2” long and the same width as the rail. I cut a rabbet in the rail and drilled holes in the rail and the covering block for the pins that hold the hook. I then screwed the covering block to the rail, enclosing the the hook and the pins. This solution makes the rail move in relation to the bed post, but I had plenty of room and this was not a problem. Not elegant, but I didn’t spill any of my blood.
-- Ride the bevel!
View canadianchips's profile
canadianchips
2600 posts in 2872 days
#6 posted 03-06-2017 07:00 PM
Table saw. Feather board
hope you have lots of headroom to stand rail upright while cutting
bluephi1914
#7 posted 03-06-2017 07:44 PM
ok got it… makes since
- canadianchips
i got a heavy duty Tenoning Jig and i think that will support the rail when i stand it upright
standby for update, lol
View Ocelot's profile
Ocelot
1862 posts in 2513 days
#8 posted 03-06-2017 09:27 PM
A slotting bit on a router table might also work. No, I see that wouldn’t be deep enough.
-Paul
bluephi1914
#9 posted 03-15-2017 03:11 AM
Purchased this jig on sale at woodcraft (50% off) and ended up standing the wood on edge and running it through the saw
