Grain orientation on nightstands top?
Forum topic by Tim Pursell posted 298 days ago 174 views 0 times favorited 4 replies Add to Favorites
View Tim Pursell's profile (online now)
Tim Pursell
217 posts in 310 days
298 days ago
This is the first design of a pair of Nightstands I am building.
Nightstand 1
As drawn, the lower shelf was solid with the grain running front to back, I just planned to make the top with the same orientation. Then I got creative and changed the shelf to spindles, as I have on other tables (all square). Now I can’t decide which way to make the top. Ideas??
Here’s the final drawing:
Night Stand version 2
Sorry about the photo size—for some reason I cannot get it to the same size as the first version.
Also,I’m using Quarter sawn white oak, so the grain is really going to be noticed.
-- http://www.grandprairiewoodworks.com
View waylan's profile
waylan
5 posts in 311 days
297 days ago
Well, from the second image it appears that the stand is narrower (side-to-side) that is is deep (back-to-front). While running the the long way often makes sense, you will then have end grain on the front, which I would generally try to avoid. I’d run the grain side to side. Just my 2cents.
-- Waylan Limberg, Warren PA
View Russel's profile
Russel
1307 posts in 467 days
297 days ago
Personally, I’d have the top grain running side to side, I’m not found of looking at the end grain right in the front of the table. But, if you make the top spindles like the shelf, it really doesn’t matter. ;-)
View Red Headed Merganser's profile
751 posts in 702 days
297 days ago
Eh, if you sand your endgrain enough, that shouldn’t matter as much, either! ;) Don’t need to sand it with a higher level of sandpaper – just need to sand it a bit more with the same level sand paper. Try it on a test piece – it works. I was able to get endgrain on santos rosewood to not be any darker than the long grain just by making sure I’d sanded the endgrain enough.
But that’s just me stirring the pot. I prefer the grain running side to side, too. :)
-- Ethan, http://www.merganserwoodworks.com, http://greystonegreen.blogspot.com/
View sandhill's profile
sandhill
277 posts in 452 days
296 days ago
My choice would be side to side, I like the spindles on the bottom. Are you going to use white oak? Your other option could be to make it a bit shorter (what ever looks good) and run a board across the end grain. When I use walnut I like to use maple to add contrast but I dont know how that would look on oak or cherry if you use them.
-- Just another day in paradise.
Bookmark And Share This Page
