Small Box Wood Movement Question
Forum topic by LSGss posted 03-05-2017 04:01 PM 601 views 0 times favorited 6 replies Add to Favorites Watch
View LSGss's profile
LSGss
61 posts in 2134 days
03-05-2017 04:01 PM
Hello all,
Quick question to those with more experience. I am building a small box approximately 6” deep, 8” wide, and 4” high. I wanted to make the top of solid wood, same for the bottom. I was thinking of using a mahogany, sapele or walnut species. Can I make the top and bottom solid and glue it into a dado. Or do i still need to account for wood movement even at this size.
Thank you
Lenny
View papadan's profile
papadan
3584 posts in 3516 days
#1 posted 03-05-2017 05:38 PM
Don’t worry about movement on a project that small.
View TheFridge's profile (online now)
TheFridge
10343 posts in 1633 days
#2 posted 03-05-2017 05:43 PM
Don t worry about movement on a project that small.
- papadan
Ditto
LSGss
#3 posted 03-05-2017 06:19 PM
Great thanks for all your quick responses and help.
Lenny
View Tony_S's profile
Tony_S
924 posts in 3230 days
#4 posted 03-05-2017 09:40 PM
- LSGss
Most, if not all of the answers you get will be no. But these answers are from people who’ve never had a problem.
They should read….I’ve never had an issue, but your mileage my vary due to geographic location, and stability of relative humidity from season to season.
If I build a solid box that size, with a tight fitting, solid bottom, there would be about a 50/50 chance of problems.
Inset lids, I have to leave a full 1/16” of play to be safe, otherwise the lid will sometimes become stuck, or near stuck.
Typically, if I use a solid bottom In a dado, I’ll put a couple of dabs of silicone in the corners so the bottom won’t move with normal use and handling, but can if it does swell and/or shrink.
It’s usually no more, or not a whole lot more difficult to build it properly than not, and maybe save yourself some grief later.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View johnstoneb's profile
johnstoneb
3014 posts in 2320 days
#5 posted 03-05-2017 09:51 PM
With something that small you will have no problems.
-- Bruce, Boise, ID
View Andybb's profile
Andybb
1281 posts in 751 days
#6 posted 03-06-2017 12:29 AM
- johnstoneb
Agreed but…couldn’t hurt to follow Tony_S’s suggestions just to be safe especially the lid suggestion. I will from now on.
-- Andy - Seattle USA
