Vacuum press
Forum topic by 7Kcraftsman posted 01-30-2008 05:10 AM 1149 views 0 times favorited 6 replies Add to Favorites Watch
View 7Kcraftsman's profile
7Kcraftsman
26 posts in 3929 days
01-30-2008 05:10 AM
I recently aquired a vacuum press from a friend and I was wondering if anyone can tell me anything about it. I know nothing about veneering but have been wanting to give it a shot. The unit turns on and runs fine. Putting my thumb over the hose tells me that there is suction but I have no idea how much. I see no markings to tell me.
i have a couple of questions:
1. what size bag can this handle
2. can I add a component to make it a cycleing unit
3. do i neet to add a holding or ventury tank.
See the pictures at the following link:
http://7kcraftsman.blogspot.com/
John
35120 posts in 4396 days
#1 posted 01-30-2008 05:27 AM
John:
There are two kinds of pumps.
!) electric and they would usually have a vacuum switch that will turn the pump and and off as necessary.
2) Ventura type that use an air compressor to provide the vacuum.
The size of the bag is not an issue. Because once it’s pulled down you are sitting in a rest state while the press does it’s work. The only variable is how fast the vacuum pump can pull the vacuum out of the bag.
A slop pump would tale a longer time to get the bag evacuated.
You can add a holding tank. www.joewoodworker.com has parts to make a vacuum system.
It sounds that you might only have the pump.
I started with an electric pump that a mechanic bought to pull the vacuum in air conditioners in automobiles. He was afraid that the pump would collapse the system so he gave up and sold it.
I got it cheap.
I added a vacuum switch, and a bag and was in business. It’s quite easy to do and lots of fun. Send me a message, and a phone number if you want to talk.
#2 posted 01-30-2008 05:29 AM
I looked at your picture. It looks like a good pump and it has a filter. That is handy if you want to use the vacuum pump to make vacuum clamps. There is the possibility that dust and chips could come down the vacuum line.
View motthunter's profile
motthunter
2141 posts in 3794 days
#3 posted 01-30-2008 05:38 AM
I am jealous. I plan to make a pump this year. Good luck with it and I hope that you can make amazing things with it
-- making sawdust....
View rikkor's profile
rikkor
11295 posts in 3870 days
#4 posted 01-30-2008 10:57 AM
Can’t wait to see some projects.
View Damian Penney's profile
Damian Penney
1141 posts in 3987 days
#5 posted 01-30-2008 09:35 PM
Check out joewoodworker excellent plans/kits for making a cycling unit and all manner of great info on vacuum pressing/clamping in general.
Damian Penney
#6 posted 01-30-2008 09:38 PM
Ah I see Karson already pointed you at joewoodworker. Good luck with it, here is my first project using my press
