Delta 36-725 table saw
Forum topic by Klmoon posted 03-05-2017 02:22 PM 512 views 0 times favorited 5 replies Add to Favorites Watch
View Klmoon's profile
5 posts in 378 days
03-05-2017 02:22 PM
Topic tags/keywords: question tip
My TS is about a year old, the raise and lower crank turns freely, the gears that meet up underneath are turning freally, the shaft that goes into the saw body that raises and lowers the saw turns freely, but the saw won’t go up or down! Any suggestions?
5 replies so far
View Carloz's profile
1147 posts in 522 days
#1 posted 03-05-2017 06:48 PM
I suggest to use your 5 years warranty that comes with the saw. You still have 4 years left
View Tideline77's profile
102 posts in 702 days
#2 posted 03-06-2017 12:12 AM
They come shipped , packed with a with a styro block that must be removed before you can adjust the blade height
If you recently assembled and setup the saw and did not remove this hidden styro block
That might be the problem
5 posts in 378 days
#3 posted 03-06-2017 02:42 AM
Really? It’s a year old, still haven’t used it?
View WhyMe's profile
995 posts in 1492 days
#4 posted 03-06-2017 03:42 AM
I’d guess the elevation rod and bushing has come loose at the motor.
5 posts in 378 days
#5 posted 03-06-2017 01:44 PM
Thanks, found out it’s the the elevating bushing and spring washer is not staying stationary as it is supposed to
