Need advice on cheap vises.
Forum topic by Walker posted 03-04-2017 05:34 PM 1284 views 1 time favorited 16 replies Add to Favorites Watch
View Walker's profile
Walker
146 posts in 648 days
03-04-2017 05:34 PM
I’m in the process of building a workbench. I would like to add an end vise, but I’m already over budget so I’m looking for something cheap (<$60). I can possibly replace it with something nicer later, but for now I just need something to start with.
I’ve seen several on ebay in that range like shop fox, Olympia, Pony, irwin, etc. Are these all to be avoided? Are there any options in this price range that aren’t just an expensive paper weight?
-- ~Walker
16 replies so far
View higtron's profile
higtron
243 posts in 2853 days
#1 posted 03-04-2017 05:48 PM
this is the one I used on my bench it’s from grizzly http://www.grizzly.com/products/Cabinet-Maker-s-Vise/H7788?utm_campaign=zPage&utm_source=grizzly.com this is a picture of it on my bench
-- A friend will help you move, a good friend will help you move a body
View HorizontalMike's profile
HorizontalMike
7770 posts in 3090 days
#2 posted 03-04-2017 06:02 PM
I agree, the above is pretty much all you can get within the OP’s <$60 budget.
FWIW, ~double that and you can get a much, much better vise. I bought the 7in model of this one:
http://www.leevalley.com/us/wood/page.aspx?p=49980&cat=1,41659
Food for thought.
I put a larger jaw on mine:
View Bill White's profile
Bill White
5106 posts in 4136 days
#3 posted 03-04-2017 06:17 PM
Cheap vs: inexpensive. BIG difference.
Be very careful about your purchase ‘cause crappy vices can be money poorly spent.
Bill
-- bill@magraphics.us
Walker
#4 posted 03-04-2017 06:55 PM
@Higtron, I was looking at that model but it says its 19” long. I won’t have the clearance for that. I should specify that this will need to be under mounted, and I only have about 8 1/2” between edge of the bench and the leg post/cross member, although I haven’t actually built anything yet. The bench has to be sort of an odd size to fit in a particular spot in my basement, 96×32”.
Grizzly has some shop fox vises that look similar to the Lee Vally one Horizontal Mike posted. I know they’re probably lesser quality but are they still work it? That style looks like it needs less clearance. I’m okay with the jaw opening not as wide.
-- ~Walker
View Ripper70's profile
Ripper70
1150 posts in 1084 days
#5 posted 03-04-2017 09:52 PM
Here’s one that might be worth a look:
http://www.ebay.com/itm/Vintage-LITTLESTOWN-PA-vise-No-197-woodworking-carpentry-bench-vise-/152459012648?hash=item237f43ea28:g:J5YAAOSwhlZYuiBY
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View onoitsmatt's profile
onoitsmatt
395 posts in 1352 days
#6 posted 03-04-2017 10:56 PM
Check craigslist. When I’m searching for vises (and for some reason I do this a lot), I always search the following:
Vise
Vises
Vice
Vices
There are a lot of things that show up that are not woodworking vises, but this covers all the bases for misspelling and also people who are selling more than one vise may not have the singular “vise” mentioned anywhere in their ad, so it doesn’t show up in a search for “vise”.
I have found many good deals on vises on CL in the last couple of years. I think you’d be able to find something good at your price. Also check antique malls, lots of old screws and vises to be found there (and flea markets, yard sales, etc).
-- Matt - Phoenix, AZ
View TheFridge's profile
TheFridge
10506 posts in 1662 days
#7 posted 03-04-2017 11:20 PM
I made 2 of my own for about 50$ish? 3/4 acme rod and nuts.
Walker
#8 posted 03-05-2017 12:37 AM
Check craigslist. When I m searching for vises (and for some reason I do this a lot), I always search the following:
Vise
Vises
Vice
Vices
- onoitsmatt
Good call. I just checked my local CL and found only top mount swivel type vises and one “Emmert pattern makers vise” for $550. I’ll keep looking though. I like searching misspellings because that usually means people don’t know what they have and sell cheap!
-- ~Walker
Walker
#9 posted 03-05-2017 12:39 AM
- TheFridge
Got a pic? What did you use for guide bars?
-- ~Walker
View Ub1chris's profile
Ub1chris
125 posts in 1556 days
#10 posted 03-05-2017 12:40 AM
Fridge has the right idea. You could easily build your own for that price. I think ShopNotes had plans but can’t check through my bookshelf now.
onoitsmatt
#11 posted 03-05-2017 12:47 AM
Go get that Emmert. Budget be damned!
View shipwright's profile
shipwright
8132 posts in 2974 days
#12 posted 03-05-2017 12:58 AM
TheFridge
#13 posted 03-05-2017 01:04 AM
http://lumberjocks.com/projects/254978 Don’t mind the girl on the bench
Walker
#14 posted 03-05-2017 01:06 AM
Walker
#15 posted 03-05-2017 01:11 AM
http://lumberjocks.com/projects/254978 Don t mind the girl on the bench
- TheFridge
wow, um… you got me with that one. That’s quite a model you got there. That bench though, is really impressive. You got every feature imaginable.
-- ~Walker
