OK to use laminate for this?
Forum topic by leftcoaster posted 03-03-2017 03:26 PM 535 views 0 times favorited 9 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
229 posts in 996 days
03-03-2017 03:26 PM
I have a Delta rolling base that I want to use for a Delta drill press. It’s one where you supply the lumber to fit the base dimensions. The instructions say to use 1.5” square hardwood, preferably cherry or oak or maple.
I happen to have some 4/4 poplar lying around. Can I laminate this to get to a size I can plane down to 1.5” and use it in place of those other species?
I might have some oak too also in 4/4 but I’d like to use the poplar if I can. My main goal is for the stand to not collapse on me….
9 replies so far
View Lazyman's profile
Lazyman
2392 posts in 1507 days
#1 posted 03-03-2017 03:40 PM
I bought one of those Delta bases at a garage sale and it came with glued up 3/4 oak and it worked just fine on my old delta table saw. I would orient the glue joints vertically so that the bolts don’t end up going horizontally through them. I needed to change the dimensions when I decided to try it with my much heavier bandsaw and used pine 2×4s to cut down to size for the new rails. It also worked but the pine definitely flexed more, especially with the heavier weight and the longer span on the longer dimension. I ended up making a more stable base for it. The drill press probably has a small enough footprint and is light enough that flexing won’t me much of a problem.
View ShaneA's profile
ShaneA
7022 posts in 2718 days
#2 posted 03-03-2017 03:41 PM
Should be fine, a drill press wont be amongst the more heavy machines you could be putting on that base.
View dhazelton's profile
dhazelton
2789 posts in 2416 days
#3 posted 03-03-2017 04:35 PM
- ShaneA
No, not the heaviest, but maybe the TOP heaviest with a small footprint. I’d reconsider making a floor standing drill press into a roller.
leftcoaster
#4 posted 03-03-2017 04:39 PM
No, not the heaviest, but maybe the TOP heaviest with a small footprint. I d reconsider making a floor standing drill press into a roller.
- dhazelton
The manufacturer acknowledges that a rolling stand is reasonable configuration and prescribes a wider plywood base to make it safe. Of course I wouldn’t use it while mobile and I’m moving 2 feet at most: away from the wall and back again. An acceptable risk in my judgment.
View xeddog's profile
xeddog
200 posts in 3127 days
#5 posted 03-03-2017 06:00 PM
I have a few of those mobile bases and I used plain old construction 2×4s ripped to width. So far, so good. But I have never put anything as top heavy as a drill press onto one of them. However, I have recently purchased a new Delta 18-900L drill press that I would like to put on one. For that one, I think I am going to to my metal supplier and get some steel square tubing for the job, and maybe some steel plate for an insert.
Wayne
Lazyman
#6 posted 03-03-2017 08:19 PM
Just a thought. Since you only intend to move it a little, you might want to look at some of the DIY drill tables mobile bases out there. I think it will be more stable overall and won’t have the big foot lever for raising it sticking out.
leftcoaster
#7 posted 03-03-2017 08:44 PM
Nathan, thanks. I was already planning on a cabinet for bits and whatnot and just found this, which looks great
http://www.woodsmithshop.com/media/pdf/707/3-in-1-drill-press-upgrade.pdf
Lazyman
#8 posted 03-04-2017 02:49 PM
Hah! That is actually the one I was thinking of when I suggested a simpler base. I just could not remember where I saw it.
View alittleoff's profile
alittleoff
541 posts in 1396 days
#9 posted 03-04-2017 03:47 PM
- leftcoaster
Very nice cabinet. If I ever get time I may build it for myself.
