sharpening jigs for belt sanders
« back to Woodturning forum
Forum topic by Karda posted 03-03-2017 06:12 AM 2113 views 0 times favorited 11 replies Add to Favorites Watch
View Karda's profile
Karda
1286 posts in 700 days
03-03-2017 06:12 AM
Hi, I have a HF belt and I want to use it to sharpen my turning tools. I looked at the article about it that was reviewed here but it is not much help because I can’t get the nplans. I have found lots of plan to make jigs but they are for grinding wheels. My main concern is I can make one from a oicture but how do you get the right angle for your tool. I’m not to mechanicaly inclined
11 replies so far
View hairy's profile
hairy
2765 posts in 3678 days
#1 posted 03-03-2017 12:56 PM
I made one. I quit using it because the sander I put on it was junk. I think I used 45 degree angle.
If I was to make another, the angle would be adjustable and not fixed.
http://lumberjocks.com/projects/29424
-- My reality check bounced...
View HorizontalMike's profile
HorizontalMike
7770 posts in 3060 days
#2 posted 03-03-2017 01:19 PM
Here is my review/how-to of what you are wanting to do with your HF sander:
http://lumberjocks.com/reviews/3179
As far as getting the correct angle, that is pretty much set by eye. If you are off by a degree or two, that really is not going to be much an issue. You will need to eventually buy or make a jig, like the tru-grind bandsaw gouge jig:
Trial and error practice will help improve here, so you may go through some steel edges learning, but it works… Good luck!
View MrUnix's profile
MrUnix
6936 posts in 2345 days
#3 posted 03-03-2017 05:04 PM
The one I made can be adjusted for angle, as I posted in your other thread about the sander :
Maybe a better picture of the jig itself:
It’s not rocket science. You can visually match the grind angle that is on the tool and lock it in. it also allows you to change the angle if desired, depending on your preference. As mentioned, a few degrees (or more) one way or the other isn’t all that critical. There are a ton of different ways to go about it, just get creative. I didn’t use any plans, just looked at what was out there and came up with my own out of what I had handy (few bolts, t-nut, scrap 2×4…).
View Lazyman's profile
Lazyman
2527 posts in 1533 days
#4 posted 03-03-2017 05:46 PM
You can see in my belt sander build blog another option that I fashioned after the Sorby pro Edge design. This might be a little more difficult to add to a “store bought” version but works very well. I built a belt sander partly because I wanted to use it to sharpen my lathe chisels after seeing youtube demos of the Sorby sharpening system.
Here is another one by Dutchy that I added to may favorites a while ago.
Karda
#5 posted 03-03-2017 06:29 PM
thanks for your suggestions, the pictures are quite helpful, and the blogs also. I got my tools today but the lathe don’t come till next week. I made a wood jig based on the 2.00 jig and am going with that for a while. I appreciate you patience, I tend to over think things and information gets in my way. Too much information and Utubes can be a bad thing Thanks Mike
MrUnix
#6 posted 03-03-2017 06:57 PM
thanks for your suggestions, the pictures are quite helpful, and the blogs also. I got my tools today but the lathe don t come till next week. I made a wood jig based on the 2.00 jig and am going with that for a while. I appreciate you patience, I tend to over think things and information gets in my way. Too much information and Utubes can be a bad thing Thanks Mike
- Karda
LOL – don’t beat yourself up over it. Sharpening angle is not extremely critical and different people prefer different angles depending on their style of turning and what they are used to. The important part is to be able to produce a consistently repeatable grind each time, which is what the jig gets you… as long as you set it up the same way each time, you will get the same grind each time, and that is 99% of the battle.
Karda
#7 posted 03-03-2017 07:00 PM
thanks for your encouragement
Karda
#8 posted 03-12-2017 09:54 PM
Hi, I ghot the sander and set uo a jig for it, I can follow the existing bevel but is it sharp, I got a lot of learning. Question HF has some diamond hones but the finest is 600 should I go finer to hone my turning tools thanks Mike
View maxhall's profile
maxhall
80 posts in 2347 days
#9 posted 03-13-2017 12:54 AM
you don’t need any finer than 600 grit. No type of tool is beat up the way turning tools are. Just for reference if you were to use a grinder the cats pajamas are CBN wheels and the grits that are most popular are 80grit (establishing the geometry you want/fixing a real buggered edge) and 180 grit (for maintenance sharpening).
Karda
#10 posted 03-13-2017 01:06 AM
ok thanks I am using a sander with 120 grit ceramic belt
MrUnix
#11 posted 03-13-2017 01:12 AM
I use them right off the belt sander – no honing needed…
