Need help in finding a M10-1.0 flat head machine screw
Forum topic by dhowell posted 03-03-2017 01:14 AM 1021 views 0 times favorited 12 replies Add to Favorites Watch
View dhowell's profile
dhowell
2 posts in 3068 days
03-03-2017 01:14 AM
Hello,
I am attempting to put a Biesemeyer fence on a very early Delta 34-410 table saw. I do not want to drill out the M10-1.0 female thread to attach the rail of the fence to the cast iron top. Biesmeyere recommends that you drill it out to fit a 7/16 dia supplied screw. Anyone have a source for a M10- 1.0 X 25mm L. The head could be any drive and the length can be up to about 55 mm. Any help would be appreciated. I have looked at every supplier I could find.
Thanks,
D Howell
12 replies so far
View Jimintomahawak's profile
Jimintomahawak
73 posts in 474 days
#1 posted 03-03-2017 01:44 AM
Try McMaster Carr they have them. I attached catalog page.
-- Laziness drives creative thinking...
View Rayne's profile
Rayne
869 posts in 1538 days
#2 posted 03-03-2017 01:44 AM
I’ve always found my metric screws from Ace Hardware stores. They even had one for my HDTV which required a very unique length to my surprise.
Jimintomahawak
#3 posted 03-03-2017 01:45 AM
View JollyGreen67's profile
JollyGreen67
1669 posts in 2761 days
#4 posted 03-03-2017 01:47 AM
Rayne is correct. Ace Hardware has a HUGE selection of metric screws.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View mrg's profile
mrg
823 posts in 2998 days
#5 posted 03-03-2017 03:51 AM
Home Depot and Lowes have them.
-- mrg
dhowell
#6 posted 03-03-2017 01:58 PM
Hello Everyone,
Thanks for your replies but none of the options have a M10-1.0 flat head. You will need a countersunk head to fit the predrilled holes in the fence.
Thanks,
Delmer Howell
View simonov's profile
simonov
62 posts in 504 days
#7 posted 03-03-2017 04:20 PM
I buy almost all my fasteners for work and play from McMaster-Carr. I’m in the firearms business, and the only fasteners they can’t supply are weird gun-related threads like #6-48 and #8-40. What I’ve found is in general, if McMaster-Carr doesn’t have it, it’s something weird or specialized.
Which means that M10×1.0 you are looking for is pretty odd indeed. I wonder why they used it.
At this point I’d start looking for a die, or a local machinist who has a die.
-- Nunc est bibendum.
View dhazelton's profile
dhazelton
2767 posts in 2295 days
#8 posted 03-03-2017 04:25 PM
simonov
#9 posted 03-03-2017 04:33 PM
Google is your friend.
http://www.homedepot.com/p/Crown-Bolt-M10-1-0-x-25-Mm-Zinc-Plated-Hex-Bolt-81008/202210123
Wow, that’s pretty good.
But OP needs a flathead for a countersink.
A machinist with a lathe could probably take those hex bolts and machine the heads into 100 degree flatheads and then cut a slot for a screwdriver.
View gwilki's profile
gwilki
201 posts in 1472 days
#10 posted 03-03-2017 04:39 PM
Where are you and how soon do you need them? I believe that I can get them locally, but I’m in Ottawa ON Canada.
I can check my local supplier to make sure but if time and distance are a problem, I can’t help you.
-- Grant Wilkinson, Ottawa ON
MrUnix
6714 posts in 2198 days
#11 posted 03-03-2017 04:40 PM
I am surprised that it uses a metric thread given it’s age… are you sure it’s not a 3/8”-24tpi thread, which is very close and pretty much the standard used on the Deltas.
View Madmark2's profile
Madmark2
379 posts in 587 days
#12 posted 03-03-2017 05:17 PM
It may not be M10-1, try a 5/16-18. M10-1 is non standard, M10-1.5 is normal. Metric fasteners follow rules for proportions that disallow M10-1. You mjght have to bite the bullet and redrill/retap.
M
