mdf vs plywood for cabinet bases?
Forum topic by Bill Szydlo posted 03-02-2017 10:28 PM 2156 views 0 times favorited 19 replies Add to Favorites Watch
View Bill Szydlo's profile
Bill Szydlo
67 posts in 2865 days
03-02-2017 10:28 PM
I am starting a kitchen project and am considering using mdf for the lower cabinet sides/top/bottom. These cabinets will be a frameless construction and will be composed entirely of drawers, no doors to look inside. They will be edged with 3/8” solid wood. I am aware of the problems with mdf (weight, dust, moisture) but I like its stability (and cost). From what I have read there appears to be a lot going for mdf in this application but I keep wondering if I should invest in the plywood or is it a toss up?
I would appreciate any insights more experienced individuals are willing to share.
Thanks,
Bill
19 replies so far
19274 posts in 2035 days
#1 posted 03-02-2017 10:33 PM
I wouldn’t do it for two reasons. First is the weight. Second is that it is hard to get screws to hold without splitting the mdf. Use the plywood. Your back will be happier.
View papadan's profile
papadan
3584 posts in 3546 days
#2 posted 03-02-2017 10:33 PM
I would not suggest MDF for frameless cabinets, the weight will cause sagging over time. Any cabinet that can get wet should be ply instead of MDF also.
View TheFridge's profile
TheFridge
10515 posts in 1664 days
#3 posted 03-02-2017 10:43 PM
Ditto and ditto
View DS's profile
DS
3025 posts in 2598 days
#4 posted 03-02-2017 10:55 PM
For the best of both worlds consider a Classic Core plywood. It is medium weight with the stability and paintability of MDF with the screw staying power of plywood.
It is a little more $$$ but well worth it for a good project.
View MT_Stringer's profile
MT_Stringer
3183 posts in 3409 days
#5 posted 03-02-2017 11:18 PM
Not bad – $40 for 3/4 inch plywood.
http://www.homedepot.com/p/Sande-Plywood-Common-3-4-in-x-4-ft-x-8-ft-Actual-0-709-in-x-48-in-x-96-in-454559/100037820
3/4 inch mdf.
http://www.homedepot.com/p/MDF-Panel-Common-3-4-in-x-4-ft-x-8-ft-Actual-0-750-in-x-49-in-x-97-in-988547/206512588
For the $10 dollar difference, it is a no brainer for me.
BTW, I hate mdf, and the dust it rode in on.
Good luck with your build.
Post some pics. We like pics.
Mike
View Woodknack's profile
Woodknack
12402 posts in 2558 days
#6 posted 03-02-2017 11:19 PM
If cost is your main concern, we all face challenges, use pine plywood and build in place. The cabinets in my house were all built in place of pine plywood in 1960, painted, and remained strong until I bought the house and started replacing them almost 40 years later. John Heisz on youtube just built all new kitchen cabinets of pine and they look great. Building in place will save dollars as it takes less material. Some people are unfamiliar with built in place cabinetry, what it means is you don’t build boxes and screw them to the wall, instead the wall becomes part of the structure and you build off it. Unfortunately I don’t have a web reference and you may have to go to the library and look up an older cabinetry book. It was the standard way of building cabinetry before mass production.
View GR8HUNTER's profile
GR8HUNTER
4943 posts in 890 days
#7 posted 03-02-2017 11:58 PM
guess you got your answer ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
all are correct USE PLYWOOD :<))
View Bob Collins's profile
Bob Collins
2587 posts in 3862 days
#8 posted 03-03-2017 12:09 AM
Agree with all above, I would use Plywood every time.
-- Bob C, Australia. Your best teacher is your last mistake.
View kocgolf's profile
kocgolf
360 posts in 2356 days
#9 posted 03-03-2017 01:16 AM
MDF or Melamine only for occasional shop projects, but for anything I really care about, definitely ply. HD has a nice PureBond brand that I have used with great success and consistency. They claim it’s better for you, no formaldehyde, but who knows. I know it works well.
Bill Szydlo
#10 posted 03-03-2017 01:29 AM
Thanks for all the help and it looks like plywood wins. I appreciate all the links from Home Depot but the nearest HD to me is 30” one way. Sadly, the only store I have local is Menards. I was just on their website and the list a 7 ply D3 plywood. I’m not up on my plywood grading but for the cabinets that will not be seen it seems the D3 will be fine. Here is the link http://www.menards.com/main/building-materials/panel-products/specialty-panels/hardwood-panels/3-4-x-4-x-8-d3-natural-maple-veneer-core-plywood/p-1444445025105-c-13334.htm?tid=7958673062394043621&bargainStoreId=3177.
The other item I was considering was using a pre finished birch plywood and am curious what your thoughts are.
Thanks again.
#11 posted 03-03-2017 01:35 AM
I much prefer menards plywood over any other store. MDO is a great choice too, but it’s expensive. Prefinshed is a great choice too, but it can be difficult to glue to.
Bill Szydlo
#12 posted 03-03-2017 01:36 AM
Would melamine glue work on prefinished panels?
#13 posted 03-03-2017 01:42 AM
I have no idea Bill. I’ve never used it. If your making cabinets though. You can use screws from the outside and they will never be seen
MT_Stringer
#14 posted 03-03-2017 03:11 AM
Here ya go, Bill.
Plywood grades
http://www.ezwoodshop.com/plywood/plywood-grades.html
I looked at the Birch plywood I normally buy for shop cabinets and paint grade cabinets. It is designated C3.
http://www.homedepot.com/p/Columbia-Forest-Products-3-4-in-x-4-ft-x-8-ft-PureBond-Birch-Plywood-165921/100077837
View Loren's profile
10477 posts in 3826 days
#15 posted 03-03-2017 04:03 AM
I say go for it. MDF and melamine are more
similar than different compared to plywood
and melamine is pretty standard for commercially
produced frameless cases.
The main drawback for the small shop is the
weight. Ultralight MDF is available but it doesn’t
stay as flat… still it probably stays flatter than
ply as a rule.
Your small-shop frameless cases are probably
going to screw together a little out of square…
that’s what the back is for, to shift the out
of squareness to the rear so so front is square.
All said, though, ply being lighter I prefer working
with it to MDF and I suppose ply holds screws
a little better.
