Heavy Duty Kerf Cut Hinges
Forum topic by jake7738 posted 10-04-2010 03:06 AM 1376 views 0 times favorited 2 replies Add to Favorites Watch
View jake7738's profile
1 post in 2728 days
10-04-2010 03:06 AM
Topic tags/keywords: kerf cut hinges hinges
I’m looking for some good reliable HEAVY DUTY KERF CUT HINGES. I have only been able to find some for small projects. The specific project I would like to use these on are for a chair so this needs to support the weight of a person. I like that a kerf cut hinge is mostly concealed. I’m open to similar solutions if anyone has some suggestions.
2 replies so far
View polyhedron's profile
18 posts in 2781 days
#1 posted 10-21-2010 05:28 AM
The heaviest kerf cut hinges I’ve seen are YoungDale. I’m not sure that’s going to be heavy enough though.
-- Matt, The Cabinet Bumper Store - - Use Promo Code: LJ2017 for 10% OFF
View Scott Walton's profile
Scott Walton
3 posts in 2615 days
#2 posted 01-24-2011 10:40 PM
Might I recommend at least a 10mm barrel hinge. Minimum thickness for the wood is 1/2. I would not use a kerf hinge… to small and then you have to think about the thickness of wood on either side… then there are the small barbs. Yes, they are good for boxes ect but if your wanting the person to be on the floor… after the hinge breaks, that’s another story.
-- Walton Woodworks Ltd.
