igaging combo squares
« back to Hand Tools forum
Forum topic by corelz125 posted 03-02-2017 07:03 PM 875 views 0 times favorited 17 replies Add to Favorites Watch
View corelz125's profile
corelz125
512 posts in 1097 days
03-02-2017 07:03 PM
Anyone own or tried the igaging combo squares? How accurate are they?
17 replies so far
View MAKZ06's profile
MAKZ06
69 posts in 1925 days
#1 posted 03-02-2017 09:56 PM
I have a couple different sizes of the double squares. They are accurate and work but they are a little rough and not in the same league as Starrett. Thumb screw adjustment is rough as well as the sliding functionality. Just feels gritty and poorer fit and finish. Measurement indications are well defined, precise and easy to read.
corelz125
#2 posted 03-02-2017 11:15 PM
Seen a 12” and 6” combo for $40 a lot less than the starrett
View Woodknack's profile
Woodknack
12341 posts in 2501 days
#3 posted 03-02-2017 11:27 PM
Keep in mind, just because they look the same doesn’t mean they are the same. When you buy cheaper tools you are buying cheaper made tools. The iGaging stuff looks nice in the pictures but for just a little more you can buy an American made PEC blem from Harry Epstein or Taylor Tools which is a whole ‘nother level of quality.
corelz125
#4 posted 03-03-2017 12:28 AM
Last i checked harry epstein didn’t see combination squares
Woodknack
#5 posted 03-03-2017 12:55 AM
You suck at checking, lol.
corelz125
#6 posted 03-03-2017 01:20 AM
OK just seen 12” 2 PC METRIC/FRACTIONAL COMBINATION SQUARE (USA) for $24. These are the way to go rick?
View PollyB's profile
PollyB
11 posts in 1149 days
#7 posted 03-05-2017 02:16 PM
I just bought a 12” combination square and a 6” double square PEC blems from Taylor Tools. Both are dead spot on accurate and have all the quality I want in my shop. I’m pleased and impressed. The blems are not readily noticeable and are something you actually have to look for to find. As I recall, I got both for $46 plus shipping out of e-bay; had ‘em in three days, very well packed. I think they are an excellent value.
-- PollyB, On my boat
View Carloz's profile
Carloz
1147 posts in 712 days
#8 posted 03-05-2017 02:30 PM
View pintodeluxe's profile
pintodeluxe
5741 posts in 2934 days
#9 posted 03-05-2017 06:51 PM
I have a lot of igaging stuff, and I like most of it.
I use a 6” double square as my daily tool. It is square, but I agree with others that the sliding action isn’t the best. I also don’t care for the 32nds and 64ths side of the ruler. I actually go out of my way to avoid that side because the scale is so hard to read.
I actually wish someone would make one with just 1/16” scales. Even 1/16 and 1/32 scale would be okay. I never use 64ths.
PollyB
#10 posted 03-05-2017 07:05 PM
I use a 6” double square as my daily tool. It is square, but I agree with others that the sliding action isn t the best. I also don t care for the 32nds and 64ths side of the ruler. I actually go out of my way to avoid that side because the scale is so hard to read.
- pintodeluxe
The PEC models have optional choices of scales. The “R” selection, if I recall correctly, has 4 scales: 1/8, 1/16, 1/32, and 1/64. Very nice, machined and easy to read.
Woodknack
#11 posted 03-05-2017 07:16 PM
I’m with Pinto, I tend to avoid the 32/64 side.
Handy chart.
View GlenintheNorth's profile
GlenintheNorth
244 posts in 657 days
#12 posted 03-06-2017 02:11 AM
Ever since I bent the butter-soft tip of my igaging marking knife (..dropped it on pine. PINE!) I have steered clear of igaging. Someone else’s mileage may vary, but I think better can be had for the money.
-- MFia-made man. But that doesn't mean I don't dig my 45. Minneapolis/St. Paul, burbs.
View MrRon's profile
MrRon
4992 posts in 3364 days
#13 posted 03-07-2017 07:13 PM
When it comes to square, a combination square MUST be precise. A square that is off by as little as 15 minutes (1/4°) is out 1/64” in 12”. 1° error would mean 1/8” in 12”. Of all the measuring tools used in woodworking, the combination square is one you don’t want to compromise on. My choice for an accurate square is Starrett, B&S and Mitutoyo; all expensive, but worth every penny.
View Ocelot's profile
Ocelot
2032 posts in 2759 days
#14 posted 03-07-2017 07:25 PM
I have the 6” PEC double square and it’s fine. I can’t see any light between it and my Incra “guaranteed” square.
Also, if you drop it. (Not saying I did, ‘cause I never drop a measuring tool), the pin which holds it together might break – and Taylor Toolworks sells that part. It’s $7, but better’n byin’ a knew won.
View Madmark2's profile
Madmark2
388 posts in 709 days
#15 posted 03-07-2017 07:46 PM
Incra T rules:
The holes are brilliant . . .
M
