How should I cut a leg vise to shape?
Forum topic by Dan Wolfgang posted 03-02-2017 05:09 PM 1131 views 0 times favorited 7 replies Add to Favorites Watch
View Dan Wolfgang's profile
Dan Wolfgang
175 posts in 924 days
03-02-2017 05:09 PM
Topic tags/keywords: question workbench vise leg vise
I’m building a Benchcrafted-ish workbench and am now thinking about the leg vise. I’ve got a nice big piece of hard maple for it, just over 2.5” thick. I’m wondering how to cut it to shape. I like Benchcrafted’s design with the curve as it gets towards the top, but I don’t know how to cut that curve. I don’t have access to a band saw or a spindle sander. I’d use the coping saw to cut a curve normally, but at 2.5” thick I wonder if that would take me, like, a year to do. How else can I cut it?
I’m wondering if I’ll just lean towards a straight taper, simply because I can do that…
7 replies so far
View Ron Aylor's profile
Ron Aylor
2649 posts in 764 days
#1 posted 03-02-2017 05:28 PM
Wow, Dan … six of one half a dozen of the other! The straight taper is nice, and easy as you say. I like this shape … and YES, I’d use a coping saw!
... my poor old leg vice is but 3-1/2” wide straight down!
View TheFridge's profile
TheFridge
10096 posts in 1603 days
#2 posted 03-02-2017 05:32 PM
Handsaw or coping saw to get most of the waste out.
Block plane skewed to refine it.
Rasp and/or files to clean it up. Or sand paper.
View Hammerthumb's profile
Hammerthumb
2886 posts in 2092 days
#3 posted 03-02-2017 08:00 PM
Could also use a jig saw.
-- Paul, Las Vegas
View BenDupre's profile
BenDupre
677 posts in 605 days
#4 posted 03-02-2017 08:52 PM
If you cant bandsaw that and you dont have one of those old timey Roy Underhill type bow saws, then i would be practical. There is no function to the curve. Cut a taper and be done.
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
Smitty_Cabinetshop
15514 posts in 2735 days
#5 posted 03-02-2017 09:59 PM
I’m going to go out on a limb and suggest you’re looking to the Gallery to let you off the hook. :-) Well, I won’t be an enabler to shortcuts. Get a new blade for your coping saw and get busy. You’re a woodworker, right? Then work the wood! It’ll be a source of quiet pride afterward, knowing what you did to get it done the way you wanted it done all along.
Dan Wolfgang
#6 posted 03-03-2017 01:59 AM
Thanks for the feedback, all. I’m glad to hear the coping saw is what others would use. I was concerned the thick slab would make it horrible, but if others would attack it that way, that’s what I’ll do!
TheFridge
#7 posted 03-03-2017 02:14 AM
It doesn’t have to be perfect. It just has to be close enough to clean up.
