Cutting wood strips: band saw resawing vs. table saw?
Forum topic by huyz posted 03-02-2017 05:05 AM 3432 views 0 times favorited 11 replies Add to Favorites Watch
View huyz's profile
huyz
58 posts in 942 days
03-02-2017 05:05 AM
Topic tags/keywords: resawing resaw strips bandsaw band saw table saw warp twisting warping planing
Hey lumberjocks!
I’m trying to cut wood strips about 1.75” x 0.4” x 48” long and wondering what method would be better. Mainly I’m unsure about how much sanding (?) is required off the bandsaw, and how much warp would typically be caused by both methods.
Method 1: buy 8/4 or 10/4 lumber (if available), plane to 1.75” then cutting 0.4” strips along the 48” length (on a table saw?). I believe cuts on the table saw would be smoother than the band saw.
Method 2: buy 5/4 lumber, resaw into halves on the band saw for about 0.5” pieces, plane to 0.4” and cut to 1.75” on table saw.
Is method 1 safer? Would one method tend to cause more tension release due to board thickness, requiring more planing to fix and wasting time/material? How long should one wait after resawing or cutting strips to see if any warping will occur?
Lots of questions, but thanks in advance for the help!
11 replies so far
View HokieKen's profile
HokieKen
5827 posts in 1219 days
#1 posted 03-02-2017 12:39 PM
I think that method 1 would likely give you more stable strips. However, I imagine they’ll be flexible enough it won’t really be a big issue anyway depending on the wood you’re using and what you’re using it for.
I would definitely use the tablesaw. It’ll give you a better finish off the blade and be much faster IMHO. Method 2 would be the safer because it will give you more space between the blade and fence for push stick but either is fine as long as you’re smart/safe about it.
-- Kenny, SW VA, Go Hokies!!!
View EugdOT's profile
EugdOT
226 posts in 636 days
#2 posted 03-02-2017 01:15 PM
Method 1Table saw is the way to go for safety and accuracy , but make sure you have a rip blade lower tooth blade especially on 8/4. To get better results and decrease bogging down the saw.
View rwe2156's profile
rwe2156
3034 posts in 1561 days
#3 posted 03-02-2017 02:06 PM
I would go with the TS, too. You can rejoint one face between cuts if desired, but if you have a good quality rip blade and use feather boards, you should get a pretty clean cut.
The only issue might be a board wanting to bow due to stress, but even so, with good featherboards holding it should still be ok.
Be sure you have a good zero clearance insert that will help.
View bbasiaga's profile
bbasiaga
1239 posts in 2076 days
#4 posted 03-02-2017 02:53 PM
Make sure your bandsaw is set up well, with a good resaw blade and cut them a bit thick. Way less waste. Plane them to exact thickness to eliminate saw marks. So that would be option 2 for me.
Brian
View Bill White's profile
Bill White
5007 posts in 4041 days
#5 posted 03-02-2017 03:30 PM
Be SURE that you have a good glue line rip blade on the table saw.
Bill
-- bill@magraphics.us
View Jim Finn's profile
Jim Finn
2663 posts in 3002 days
#6 posted 03-02-2017 11:34 PM
I do this often, and use my table saw with a 24 teeth “Planer” blade. I have a good band saw that I use to re-saw with but not for narrow stuff like you are considering. The cut of my table saw requires very little sanding, if any, sanding Band saw cuts do require sanding.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
View huyz's profile
huyz
#7 posted 03-02-2017 11:49 PM
Thanks everyone!
None of you seem to be concerned about warping, so maybe it’s not a big a deal as I thought. I will be using walnut.
It seems like a toss up in terms of which method, and maybe more a decision about which lumber is cheaper to buy and creates less waste from off cuts (not counting blade kerfs).
View knotscott's profile
knotscott
8099 posts in 3456 days
#8 posted 03-02-2017 11:54 PM
A BS blade is generally thinner in it’s thickness, but can be as wide or wider in it’s overall kerf in the wood due to much higher deviation and rougher cut. By the time you plane it down, I’m not convinced that a BS will waste any less material, and I definitely think it will take more time. It’s likely the safer method.
A TS cut is without question smoother, more accurate, and involves fewer steps.
View MrUnix's profile
MrUnix
6845 posts in 2279 days
#9 posted 03-03-2017 12:13 AM
I make thin strips using both the band saw and table saw. The ones cut on the band saw generally need a little cleaning up before using, but it depends on what it’s going to be used for. For thin strips to be used for inlays, edge banding and other similar uses, the table saw produces a much cleaner cut and in most cases can be used as-is, with maybe just a light pass with 220 grit before glue-up. For consistent size across pieces, a thin-rip jig is really handy… here is my homemade one:
(works on both the band saw and table saw)
By no means the only method, and if you do a search for thin-rip on the site, you will find lots of other alternatives – both home made and store bought.
View unclearthur's profile
unclearthur
182 posts in 1868 days
#10 posted 03-03-2017 01:04 AM
- EugdOT
Curious as to why method 2 (cut 0.4” strips from 8/4 wood on TS) is safer / more accurate than method 1 (resaw/plane to 0.4”, then cut 1.75” strips on TS) .... Not disagreeing, just curious why.
runswithscissors
2804 posts in 2106 days
#11 posted 03-04-2017 08:16 AM
Almost all the thin strip jigs I have seen (including the ones here) require the fence to be moved for every cut. Mine doesn’t. And you can safely cut thin strips down to less than 1/16” (depends on how much runout on your blade, and how straight your wood is).
Google “Thin strip cutting jig for TS” by runswithscissors (that’s me). It is somewhat limited in length, but it would be easy to make it long enough to handle 48”.
