Question on clamping frame & panel doors
Forum topic by AlbanyTim posted 10-02-2010 06:54 PM 1174 views 0 times favorited 3 replies Add to Favorites Watch
View AlbanyTim's profile
AlbanyTim
5 posts in 2901 days
10-02-2010 06:54 PM
Topic tags/keywords: frame panel doors clamp joining
Howdy,
I’m completing my first classic frame and panel door – an exterior entry door. I purchased pipe clamps so I can span the 7’ tall distance with my clamps, but now it seems like clamping the height of the door is completely unnecessary; the stiles run the entire length and lock everything in place. In fact, there doesn’t seem to be anything for a lengthwise clamp to do; there is nowhere for the rails to go since their tenons are locked into the mortises of the stiles. Does that sound right? Should I not bother using lengthwise clamps? Or is there something I’m missing?
Thanks for any thoughts you have to share!
-- Tim, Albany Wisconsin
3 replies so far
View uffitze's profile
uffitze
199 posts in 2952 days
#1 posted 10-02-2010 07:21 PM
you are correct.
the only reason why you might need a longer clamp is if your glue up is out of square, in which case, you can use it diagonally to square things up.
View Gregn's profile
Gregn
1642 posts in 2981 days
#2 posted 10-02-2010 07:31 PM
Ditto with Uffitze.
View cutmantom's profile
cutmantom
405 posts in 3032 days
#3 posted 10-02-2010 08:34 PM
some doors have a center stile that would require clamping prior to installing the side stiles and clamping them
