Ripping 1-3/4" cherry don't have a rip blade
Forum topic by Michigander posted 03-01-2017 04:45 PM 2213 views 1 time favorited 16 replies Add to Favorites Watch
View Michigander's profile
Michigander
220 posts in 2622 days
03-01-2017 04:45 PM
Topic tags/keywords: ripping thick cherry rip blade vs general purpose
I need to rip about 10 pieces of cherry 1-3/4” thick and 70” long. My general purpose blade broke so I need to buy a new blade. I don’t do enough thick ripping to justify a special purpose ripping blade, so am thinking to get a new general purpose blade. I’d like a flat tooth configuration to handle tenons and I have a thin kurf crosscut blade for crosscuts. I am partial to Frued, but am open to all suggestions. I don’t have a jointer or planer so I need to get a glue ready surface. This is for a table top and bench project.
Thanks for your help.
John
16 replies so far
View waho6o9's profile
waho6o9
8524 posts in 2779 days
#1 posted 03-01-2017 05:04 PM
View rwe2156's profile
rwe2156
3171 posts in 1683 days
#2 posted 03-01-2017 05:31 PM
Get the Freud glue line rip you won’t regret it.
View DalyArcher's profile
DalyArcher
116 posts in 1322 days
#3 posted 03-01-2017 05:32 PM
I don’t think you will get a true flat grind blade outside of a ripping blade. I have a freud combination blade which has a flat raker tooth, but the 4 other teeth I believe are ATB and those leave the little bat ears on a groove setup. I think a good ripping blade is worthwhile investment if for nothing else than to get nice, clean flat bottoms when building shaker style doors.
View JayT's profile
JayT
5961 posts in 2414 days
#4 posted 03-01-2017 06:02 PM
I wouldn’t try ripping cherry that thick with a combination blade, it’s a recipe for burning the wood and a real workout for the saw (and you). Do you really want to sacrifice the quality of the project over the cost of a saw blade? If you bite the bullet and buy a rip blade, with the crosscut you’ve already got, you will be set up for most situations.
rwe’s suggestion of the Glue Line Rip blade is a good one and would be my first choice. It uses a Triple Chip Grind, so will get you a nearly flat cut for tenons, too.
Another option to consider would be an inexpensive, but good quality rip blade. The Diablo D1024X costs about half what the Glue Line Rip does, but doesn’t leave quite as good of a finish (good enough for most glue-ups with a well tuned saw, however) and the ATB grind won’t ever give a flat cut. It might be worth the investment to get a good result on the project, however. There is also the similarly priced Irwin Marples line that has gotten some good reviews, but I haven’t used one to be able to speak personally about the performance.
View pintodeluxe's profile
pintodeluxe
5798 posts in 3016 days
#5 posted 03-01-2017 06:20 PM
I use a LU86 Freud 40 tooth combination blade for ripping most hardwoods. If I was cutting 1-3/4” thick lumber I would use a Diablo 1024. They are quite affordable and available at Home Depot.
View knotscott's profile
knotscott
8150 posts in 3578 days
#6 posted 03-01-2017 06:21 PM
The Freud 30T Glue Line Rip blade (LM74/LM75) is only recommended for stock up to 1”. It uses very tight side clearances to create a polished edge, which would likely lead to increased burning in 1-3/4” thick cherry.
A good 24T rip blade will have far less tendency to burn in stock that thick. If you get one with a flat top grind (FTG), it’ll also provide truly flat bottoms for tenons, splines, grooves, etc. You didn’t mention what saw you have, but the Freud LU87 is their 3/32” thin kerf, while the LM72 is the full kerf version. Infinity, CMT Industrial also have excellent choices. If you’re not interested in a flat bottom kerf, the Irwin Marples and Diablo D1024X will do fine for < $30.
FTG is the only flat bottom grind. None of the general purpose or combo blades with an ATB or ATB/R grind will leave a truly flat bottom.
View Slider20's profile
Slider20
119 posts in 724 days
#7 posted 03-01-2017 06:43 PM
I have a simple philosophy with tools, I’ll spend more to be sure I’m getting what I want without making myself too crazy.
I use a forest woodworker II, regular kerf. I rip 2x lumber all the time, not much burning, just make sure your Saw is tuned.
DalyArcher
#8 posted 03-01-2017 07:49 PM
View dalepage's profile
dalepage
367 posts in 1043 days
#9 posted 03-02-2017 02:21 AM
Absolutely buy a ripping blade. Using the wrong tool for the job is, in the long run, a set-up for accident. I’m going out on a limb and guessing you don’t have many HP in your saw motor either. Time for a change!
-- Dale
Michigander
#10 posted 03-02-2017 09:14 PM
Thanks everyone for your input. I’ve decided to get a dedicated rip blade. I chose the Freud LM72R010. I picked this blade because it has a full kurf, straight ground teeth, but above all it is rated for thicknesses over 1 1/2” . This blade is the silver coating, but is identical to it’s red Teflon coated brother LL72R010. The silver coating saves about $15.00 over the Teflon version. I could find neither in Stock within driving distances, so bought it on Amazon for $50.00. I’ll let you know how well it works. I have a Steel City saw, which I think is 1- 1/2 hp.
Again, I appreciate your help.
View Bill White's profile
Bill White
5128 posts in 4163 days
#11 posted 03-02-2017 09:45 PM
You’re kiddin’ yourself by not havin’ a really good rip blade. Not tryin’ to be snarky, but that blade is a MUST.
Well, ya beat me to my comment.
“Silver” is good, and works well on wood like pine too.
Bill
-- bill@magraphics.us
View avsmusic1's profile
avsmusic1
273 posts in 888 days
#12 posted 03-03-2017 03:26 AM
Out of curiosity, have people found there is much to those recommended thicknesses?
View Andybb's profile
Andybb
1517 posts in 806 days
#13 posted 03-03-2017 06:55 AM
I’d second the idea of getting a decent but inexpensive big box store rip blade. Use it for your project then put your good combo blade back on and use it to joint the edges. Just my $0.02 worth.
You said your general purpose blade BROKE? As in cracked, split? What?? Yikes!!
-- Andy - Seattle USA
View shawnn's profile
shawnn
124 posts in 1568 days
#14 posted 03-03-2017 07:24 AM
I use the Freud 30T GRP. On Cherry especially I will cut slightly wide on the first pass then a “whisker” (~1/2 kerf), quick pass for final sizing. Try it before buying a new blade.
ETA Try not to stop the board during the cut, keep it moving or the blade heats the area it’s on & burns it.
Michigander
#15 posted 03-08-2017 05:32 PM
UPDATE, I decided to go ahead and buy a dedicated rip blade and am glad I did. I purchased the Freud LM72R010. It’s a flat tooth ground blade, with “silver” coating and it cut that 1-3/4” cherry like it was butter. Some reviews on Amazon said the blade created excessive sawdust and was loud. I found neither to be the case. I cut 70” long boards and has absolutely no burning. I am a believer; get the right tool for the job!
Thanks for your input!
John
