How would I tighten my table saw blade?
Forum topic by Robert Stockwell posted 03-01-2017 04:27 PM 862 views 0 times favorited 10 replies Add to Favorites Watch
View Robert Stockwell's profile
Robert Stockwell
8 posts in 678 days
03-01-2017 04:27 PM
I have a Freud 60mm by 28-Teeth motorized table saw blades, but it doesn’t t work very well because the saw wobbles terribly. How would I tighten table saw blade?
10 replies so far
View mat60's profile
mat60
34 posts in 577 days
#1 posted 03-01-2017 04:40 PM
Danger…Are you saying the blade is bent or you cant get the blade to tighten? Do not use it like that Robert.
View mudflap4869's profile
mudflap4869
1832 posts in 1580 days
#2 posted 03-01-2017 04:42 PM
You might be missing a blade collar that goes between the blade and the retainer nut. Without it you will never be able to safely use the saw.
-- Still trying to master kindling making
5073 posts in 2614 days
#3 posted 03-01-2017 04:49 PM
I’m going to guess that’s a 160MM blade (6+”), if true can you explain a little more about what saw it’s on. As mentioned, in the meantime do not use it.
View waho6o9's profile
waho6o9
8363 posts in 2698 days
#4 posted 03-01-2017 04:51 PM
Unplug it, take it apart and please post pictures of all the parts.
Great advice above
View Bill_Steele's profile
Bill_Steele
408 posts in 1853 days
#5 posted 03-01-2017 09:49 PM
I agree with the others—we need more information before we can diagnose the problem. Please provide pictures of your saw and specifically the arbor (place where saw blade is attached). If you could include a video or provide a link that would help too.
Are you sure the problem is not with the saw blade? Inspect the blade to see if it is bent or has damaged/broken/missing teeth.
I think it’s typical that a saw blade connects to an arbor that might look like the picture below:
If your arbor is damaged in some way (e.g. damaged threads, excessive bearing run-out, missing parts, etc.) this might account for your inability to tighten the saw blade and/or the wobble you are experiencing.
Unplug your saw before removing or installing the saw blade.
To tighten a saw blade on my old Jet contractor saw, I use a scrap of wood—lightly wedged at the back of the blade—to keep the blade from spinning while I tighten the nut on the arbor. I use one hand to hold the wood scrap (blade holder) and the other to tighten the nut with the supplied wrench. Don’t use any more force on the blade holder than is necessary to keep the blade from spinning. There is no need to get the nut extremely tight. The reverse threading will ensure that it does not loosen while spinning.
The threads on the arbor are reverse threaded—turn the nut RIGHT to loosen and LEFT to tighten.
I hope that helps.
View Woodknack's profile
Woodknack
12341 posts in 2501 days
#6 posted 03-02-2017 01:10 AM
Put a matchbook under one leg.
View chrisstef's profile
chrisstef
17637 posts in 3127 days
#7 posted 03-02-2017 01:16 AM
Thats funny ^
View JBrow's profile
JBrow
1366 posts in 1041 days
#8 posted 03-02-2017 12:31 PM
Robert Stockwell,
Assuming the table saw is an American saw with an imperial arbor and the saw does not “wobble” with other saw blades…
Since the blade is metric, perhaps the arbor hole on the blade is also metric and thus fits sloppy on the Imperial arbor. If this is the problem, then a properly sized bushing would be required to run the blade but I doubt having luck finding the right sized bushing. If this is the case, running the metric Freud blade on the Imperial saw would be a bad idea.
Robert Stockwell
8 posts in 678 days
#9 posted 03-08-2017 11:28 AM
Thanks JBrow
Robert Stockwell
8 posts in 678 days
#10 posted 03-08-2017 11:33 AM
Thank you all so much for the replies. Greatly appreciate your help.
