Good hand-tool first projects?
Forum topic by nordichomey posted 10-02-2010 03:00 AM 3916 views 0 times favorited 13 replies Add to Favorites Watch
View nordichomey's profile
nordichomey
100 posts in 3072 days
10-02-2010 03:00 AM
For those who like to work with traditional hand-tools… What are some good projects for someone (me) who wants to work on developing my hand-tool skills? I like a challenge, but….
-- nordichomey
13 replies so far
View swirt's profile
swirt
2662 posts in 2942 days
#1 posted 10-02-2010 05:23 AM
I agree with 3fingerpat’s suggestion of a pair of sawbenches and other shop aids that will further help in your use of hand tools (bench hook, shooting board, workbench, tool tote…)
View Gregn's profile
Gregn
1642 posts in 2953 days
#2 posted 10-02-2010 05:30 AM
Depends on what your skill level in joinery is as to the type of project you want to do. Pat has a neat project that is also pretty handy and has some tenon and mortise joinery using drawbore mortise and tenon joinery. A good solid joint for a project. Then again I also agree with Jorge with doing a step stool with a combination of dovetails and mortise and tenon joinery. You could also make a side table with a drawer to make several different joints from dovetails and mortise and tenon joints as well as a half lap joint in a bottom stretcher mortise and tenon into the legs. How equipped you are for hand tools will also determine your limitations. Just looked at your projects which leads me to recommend Pat’s project to keep it relatively simple to start with. Drawbore joinery will allow you some fudging room with the mortise and tenon joinery. What joints have you done well with hand tools if I may ask?
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3085 days
#3 posted 10-02-2010 05:46 AM
let it bee a copple of sawbenches , yes I did say a copple of sawbenches
it will make it alot easyer to saw long boards and can dobbel as sawhorses
or have bigger things on when you work on them and the bench/a table
is tooo high and the flor is too low
Dennis
View pmayer's profile
pmayer
1026 posts in 3035 days
#4 posted 10-02-2010 01:05 PM
I agree with the step stool suggestion. Then, watch a few Roy Underhill episodes and you will get all kinds of ideas.
View helluvawreck's profile
helluvawreck
30765 posts in 2836 days
#5 posted 10-02-2010 01:21 PM
I think that simple dovetail boxes are a good place to start, then a dovetail stool with tenons; and then maybe a wall cabinet with dovetails, tenons, and a mortise and tenon door. On the shelves for the wall cabinet you could use sliding dovetails. Then maybe you could do a shaker bedside cabinet. There are many projects that you could do. There are several good books on this subject that have suggested projects in them. Another good way is to go through a series of classes whose purpose is to lead someone through a series of projects for learning hand tools. Good luck.
View TheGravedigger's profile
TheGravedigger
963 posts in 3994 days
#6 posted 10-02-2010 01:48 PM
Another idea would be a small wall cabinet – think medicine cabinet or something similar. This allows you to do dadoes, rabbets, grooves, mortise and tenon, and dovetails all in the same project. It has the added virtue that most of your joinery will be hidden by the door and trim pieces in the event that they turn out less than perfect.
Many people consider the dovetail to be the heart-and-soul of hand tool work. I disagree. I would say to first perfect your mortise and tenon joint, and move on from there.
If you’re looking for a good mortising chisel, I can highly recommend the Ray Iles models at Tools for Working Wood:
http://www.toolsforworkingwood.com/Merchant/merchant.mvc?Screen=PROD&Store_Code=toolshop&Product_Code=MS-MORT.XX&Category_Code=TBMC
-- Robert - Visit my woodworking blog: http://littlegoodpieces.wordpress.com
View canadianchips's profile
canadianchips
2600 posts in 2967 days
#7 posted 10-02-2010 01:57 PM
I agree with others. Build yourself some supprot devices to hold your work properly when using hand tools. The image of holding a 2×4 across your knee and sawing off the end, just isn’t a good one ! Make saw horses , and table that support your work. With hand tools you need to hold the material better than when using power tools. Planing lumber is a great example, you need both hands to push the plane, a method to hold your board is greatly appreciated . Chiselling mortises. A SOLID work table is very nice !(No bouncing). Cutting dovetails find a good wood vise.
nordichomey
#8 posted 10-03-2010 05:22 AM
Thanks for all the input. I had thought of the step stool, but the saw benchs never crossed my mind.
Gregn – I have not done many joints WELL withhand tools. However, I read a FW article about the 5 minute dovetail and find it a great way to practice. Just using a bunch of scrap wood I have been practicing doing a simple one pin-two tail dovetail. Projects :-) ... I just finished a torsion box workbench I will get the pictures posted this weekend.
Equipment – My hand tool equipment is limited but growing. LA block plane… recently flattened the sole and honed a sharp edge. What a difference!!! Favorite hand saw is a zona razor saw but it is limited. Advice on good cross cut hand saws to start with?
-- nordichomey
Dennisgrosen
#9 posted 10-03-2010 06:18 AM
to start with as crosscuting saw you can use and not so expencive Bachosaw
and if you feel for it changes the handle with a homemade wooden one
the bacho you can get in different prices I have the xproff as they call it
its a little thicker in the blade but that can be an advance when you ruoghcut to lenght
unfortunely the teeth is hardened so you canĀ“t sharpen it without re anealing or buy a new
but again you proppely want something like crown ,adria ,veritas ,finns pax ,
or make some framesaws and then there is japanese saws as well
there is so many brands out there so you have to deside the pricerange you want
but remember both crosscut and ripsaws
then again what shuold they cut i size as you sayd the zona is only for fine things
then what next in range to cut up or down what do you want to make in the future
Dennis
nordichomey
#10 posted 10-03-2010 04:28 PM
Dennis – Thank you for the insight!
3fingerpat – Great review! You have some great reviews. I really like Landon’s tool box. Looks like a fun project. You better build him a handy manny tool box as well. I have a 4 year old who wants me to build one of those.
-- nordichomey
nordichomey
#11 posted 10-03-2010 06:39 PM
just down loaded the pictures to the computer… Do you have to use photo bucket to post? My wife is much better at this.
-- nordichomey
nordichomey
#12 posted 10-03-2010 07:13 PM
The new bench is posted!
-- nordichomey
View ShannonRogers's profile
ShannonRogers
540 posts in 3757 days
#13 posted 10-04-2010 09:02 PM
I may be blasted for self promotion here, but I am creating a hand tool school over at my Renaissance Woodworker site that is designed for just this scenario. I completely agree with many of the suggestions above and will be launching this virtual school on October 16th. The first semester will be 12 lessons over 6 months designed to teach the basics and include many small projects for use around the shop. The final project will be an out of the shop furniture piece. I’m still filming and editing the HD video content but I hope the school will meet some needs and grow with the students based on their suggestions and desires.
-- The Hand Tool School is Open for Business! Check out my blog and podcast "The Renaissance Woodworker" at www.renaissancewoodworker.com
