Designing a long box
Forum topic by Bret posted 02-28-2017 12:51 PM 441 views 0 times favorited 5 replies Add to Favorites Watch
View Bret's profile
Bret
166 posts in 3667 days
02-28-2017 12:51 PM
Topic tags/keywords: design question
I’m designing a cart/enclosure for my BBQ smoker (a Weber Smoky Mountain). I’m envisioning the unit being roughly 3’ high by 3’ deep by 8’ wide.
Which is better—building two 3×3 frames and connecting them using 8’ stringers, or building two 3×8 frames and connecting them with 3’ stringers? Is there a construction/strength reason for doing one over the other, or is ti largely a matter of aesthetics?
-- Woodworking is easy as 3.14159265358979323846264338327950288419716939937510...
5 replies so far
View johnstoneb's profile
johnstoneb
3033 posts in 2345 days
#1 posted 02-28-2017 02:20 PM
It’s your design and you know what kind of lumber is available. If you can get straight 8’ lumber go with 8’, if not go with shorter.
-- Bruce, Boise, ID
View mike02130's profile
mike02130
170 posts in 845 days
#2 posted 02-28-2017 08:42 PM
Do you have a picture? Stringer?
-- Google first, search forums second, ask questions later.
View JBrow's profile
JBrow
1366 posts in 1093 days
#3 posted 02-28-2017 11:53 PM
Bret,
Building the 3’ x 3’ frames first and then connecting them with the 8’ rails might be easier. The 3’ x 3’ frames would be easier for me to handle during construction. I can think of no structural advantage of building one sized frame over the over first.
View dhazelton's profile
dhazelton
2789 posts in 2469 days
#4 posted 03-01-2017 12:40 AM
I say six of one, half dozen of the other. You’re really just talking about where the joint occurs, and if it’s not a unit being pushed or pulled around I don’t think it matters.
View MT_Stringer's profile
MT_Stringer
3181 posts in 3404 days
#5 posted 03-01-2017 01:00 AM
I realize my cart is lighter weight and considerably smaller than your plan, but it is simply four face frames attached together with a wall in the middle to add support.
I used cedar along with cedar fence pickets planed so they are sorta smooth and edged with a chamfer bit to resemble bead board.
Like already said, got any plans we can see?
Here is my project post. —> http://lumberjocks.com/projects/257570
