Location of Breaker Panel
Forum topic by AtlasRook posted 02-27-2017 06:25 PM 682 views 0 times favorited 6 replies Add to Favorites Watch
View AtlasRook's profile
AtlasRook
25 posts in 1667 days
02-27-2017 06:25 PM
Topic tags/keywords: question shop breaker
Working on putting the workshop together at the new house, the 3rd stall of the garage.
Background: Currently, there is only 1 circuit for the outlets in the garage. However the main breaker panel is right there in the garage also, so it wouldn’t be that hard to run some new circuits.
Question: should I, instead of just running a few new circuits, but a sub-panel in the garage and wire to that? Then all of the big tools are separated from the rest of the house (not sure if that’s a big plus or not). It would also, ideally, allow me to add more circuits as necessarily when needed (ie – when I want to add a 220 line for some bigger tool I don’t own yet).
View DanK's profile
DanK
26 posts in 2811 days
#1 posted 02-27-2017 06:44 PM
A sub panel would let you power down the entire shop area preventing unauthorized users. Another thing to consider is do you have enough room amperage wise in your main panel? Might benefit more from upsizing the main than adding a sub.
View them700project's profile
them700project
126 posts in 1163 days
#2 posted 02-27-2017 09:27 PM
I would go with a sub panel if you are limited in space in the main panel and have the amperage you need for the shop. If you do not have 150 amps or more I would upsize to a 200 amp panel with plenty of room in it. Depending on what you run in the garage I would suggest sizing subpanel for Dust collector, lights/radio/battery chargers, table saw and compressor all running simultaneously
View klassenl's profile
klassenl
188 posts in 2803 days
#3 posted 02-28-2017 03:21 AM
.... If you do not have 150 amps or more I would upsize to a 200 amp panel…
Don’t worry about upgrading your house panel. It will be fine. My shop/garage runs on 30 amps no problem. I also do not weld.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
View Redoak49's profile
Redoak49
3524 posts in 2133 days
#4 posted 02-28-2017 12:09 PM
How much room do you have in your main panel? If you have lots of room, then no need for sub panel.
As mentioned, a sub panel is nice. I would run all my shop circuits on a sub panel and lights from the main panel.
5093 posts in 2637 days
#5 posted 02-28-2017 02:37 PM
Pretty much what’s already been said. If you have room in the existing panel, you can use it. But there are some advantages to having a separate sub panel for this.
View rwe2156's profile
rwe2156
3090 posts in 1625 days
#6 posted 02-28-2017 03:24 PM
- DanK
This is an excellent point if there are children around!
