Anyone know anything about this Craftsman fence?
Forum topic by patcollins posted 02-27-2017 01:29 PM 1482 views 1 time favorited 19 replies Add to Favorites Watch
View patcollins's profile
patcollins
1685 posts in 2891 days
02-27-2017 01:29 PM
I have a 113 series table saw made by Emerson Electric and just happened across this fence for craftsman saws.
There is no info available for it on that site but at that price if it is a decent fence it is a steal.
19 replies so far
View TheFridge's profile
TheFridge
9608 posts in 1512 days
#1 posted 02-27-2017 01:46 PM
Looks like an align a rip. I’d save a few more bucks and get something else. It’s not that great. Serviceable at best.
View Quailguy's profile
Quailguy
56 posts in 1217 days
#2 posted 02-27-2017 02:22 PM
That is the Exact-A-Rip fence. I had one on my craftsman tablesaw for years. It was better than no fence, but not by much. Very frustrating to keep square.
patcollins
#3 posted 02-27-2017 02:28 PM
Thank you, just what I was looking for.
I m going to try this then.
View JollyGreen67's profile
JollyGreen67
1676 posts in 2789 days
#4 posted 02-27-2017 03:21 PM
Interesting, as I also have a 113 made by Emerson with that fence, and have never had a problem with it.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View xeddog's profile
xeddog
190 posts in 3033 days
#5 posted 02-27-2017 06:19 PM
I had one of those that had a .030” bow in it. I found a Delta T-2 to replace it with. Much better.
Wayne
TheFridge
#6 posted 02-27-2017 06:23 PM
- patcollins
I’d give that a shot. That’s essentially what I built to replace the align a rip on mine. Then I got a a sawstop Tsa-PFa for 144$ to replace the wooden one.
View toolie's profile
toolie
2134 posts in 2654 days
#7 posted 02-27-2017 07:41 PM
- Quailguy
disagree.very similar to the fence that came on my ridgid 2412. every bit as accurate as the Delta T2 i have on a 113 c-man.
View sawdustjunkie's profile
sawdustjunkie
384 posts in 1743 days
#8 posted 02-27-2017 07:59 PM
When I had my Craftsman 113, I got one by Muelcab. They still make them. It only took about an hour to install it and it worked great. Here is the link http://www.mulecab.com/tablesaw.html
I don’t have the saw anymore but the fence was very strong and stayed straight.
I think there is one called a Vega fence. Sold at Rockler if I remember correctly.
Both are over $200, so I don’t know if would fit your budget.
-- Steve: Franklin, WI
View EEngineer's profile
EEngineer
1103 posts in 3639 days
#9 posted 02-28-2017 04:12 AM
I call BS! This is very similar to (and copied from) the Ridgid AC1036 fence I have used on my C-man saw for the last 8 1/2 years. It is similar to the ones Ridgid sold on their saws (like the 4512 mentioned above) and if you had trouble keeping it square, the problem was with the operator, not the fence!
There is a real problem with T-square fences in general – being supported only at the front end of the saw, they can be bent out of alignment by pressure against the fence as you feed pieces through the saw. This is why I like the Ridgid design – it clamps at both ends of the fence and you cannot move it when applying pressure against the fence as you feed stock through the saw. That includes the Mulecab and the homemade fence you refereneced.
By the same token, I used the original fence that came with my saw when sold (a 113.29901 sold in the late 60’s) and had no problems with it. I still have that fence and, if you want it, I will be glad to send it to you. My biggest problem with it was the travel – it would only cut 12” to the right and 24” to the right which is why I moved to the AC1036. But square – yeah! straight – yeah! solid – yeah! Should bolt right up to your saw. PM me and we will talk.
As for the comments about “had a .030” bow in it”, that is more a reflection on the shitty Chinese quality of extrusions used in these fences, not on the design! My fence has less than .001” from one end to the other across the 30” table length!
There are lots of opinions here on LJ – not all of them have much knowledge behind them.
xeddog
#10 posted 02-28-2017 07:41 PM
I did like the design concept of the fence. Clamping tight on the back side of the table made it very solid when clamped. There were times though that I wished it was a little heavier duty. Still, I used it for a lot of years and made a lot of stuff with it. I’m not sure about the Chinese part though. This was a fence on a Craftsman saw from the late 80’s or maybe early 90’s, and weren’t they still USA made in that time frame?
There were a couple of reasons why I replaced it. One was the bow in it. I never was quite able to get a good straight edge that I didn’t have to correct. I finally did put a new face on it and shimmed it straight. Two was not being able to count on it. After clamping it down, if I had a critical cut I had to make certain that it clamped straight by measuring at each end of the fence. The back end could be off by quite a bit sometimes. Third was just needing more than 30 inches maximum.
Wayne
TheFridge
#11 posted 02-28-2017 08:40 PM
I had the knowledge of a shitty fence on mine. If it’s so perfect. Why don’t the mayor saw makers use them on their premium saws?
Oh right. Theyre not really adjustable and crap.
patcollins
#12 posted 03-01-2017 01:39 AM
A lot to think about here. I discovered this because I saw an old 113 saw on craigslist with this fence and decided to investigate.
bandit571
20244 posts in 2709 days
#13 posted 03-01-2017 02:15 AM
meh…worked for me, for30+ years…
Yes, they do “warp” a bit. Discovered that IF I add a 1×3 strip of wood, using the slots provided, I could add a small shim to make the wood strip perfectly straight. I also could “bury” part of a dado set into the wood part of the “fence”
The ONLY reason I do not have this saw anymore? No room in the Dungeon shop. Sold this saw about a year ago.
patcollins
#14 posted 03-01-2017 02:27 AM
Hey bandit, did you make a longer angle fence rail? It looks like you have three wings bolted together there on the right side of the saw.
I have this same fence currently. I have it parallel to the blade when it is up to 12 inches away, however past that it goes out of alignment, which is why I am looking for an upgrade.
bandit571
#15 posted 03-01-2017 02:44 AM
I threw out the OEM rail, and made a new, longer rail. Just simple angle iron, used the OEM mounting parts.
On the top of the fence, right above the “Tightener” are two hex head bolts. Loosen them just a hair, adjust the fence for parallel with the miter slot. Lock the fence in place, re-check. Still lined up? Torque the bolts tight. One more check. Should be good to go.
Saw came about when the trunnion broke on the original saw. Got a replacement set of parts from a similar saw. “New” trunnion, and two extra wings. I also got a larger motor, with dual pulleys. Cost of the “parts saw”? $25.
