Attaching veneer to plywood
Forum topic by AZWoody posted 02-27-2017 12:06 AM 470 views 0 times favorited 5 replies Add to Favorites Watch
View AZWoody's profile
AZWoody
1396 posts in 1338 days
02-27-2017 12:06 AM
I have a lot of pieces of eucalyptus and cottonwood that dried very wavy and not much I can use them for as lumber but I have had success getting them down to 1/8” to use as a veneer over plywood.
What would be the best glue for attaching large pieces over the plywood? I have done it successfully on a small scale with titebond but for doing long, 6’-8’ pieces, over the width of a full sheet of plywood, what would you guys use?
5 replies so far
View HerbC's profile
HerbC
1785 posts in 2973 days
#1 posted 02-27-2017 12:37 AM
Hot hide glue…
Look for LJ user Shipwright’s blogs about using HHG.
Good luck!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
AZWoody
#2 posted 02-27-2017 03:37 AM
Hot hide glue…
Look for LJ user Shipwright s blogs about using HHG.
Good luck!
Herb
- HerbC
I was considering that but is it feasible for a large sheet of plywood which will have a lot of movement and flex as it’s being moved around? I’m thinking for floor to ceiling cabinets and so while being put together, there might be some bending and bowing.
View Lazyman's profile
Lazyman
2383 posts in 1502 days
#3 posted 02-27-2017 04:34 AM
I’m no expert, I’ve only done one large veneer project, but I would look at Old Brown Glue for this. 6-8 foot long pieces might be a little challenging for hot hide glue and hammer veneering. Cold press glue for veneer may also be worth a look though I’ve never tried it. With both, you need clamps and cauls.
If your boards are wavy, it seems like you probably should use a jointer to get it flat before cutting veneer, especially with 6-8 foot pieces. If it’ is not flat, I think you are going to have problems clamping down those long strips and getting a good bond.
View Andre's profile
Andre
2006 posts in 1920 days
#4 posted 02-27-2017 04:37 AM
I use a Ink roller for larger projects, really speeds up application! Cut you Titebond with 10% water will give you another 5-10 work time.
View shipwright's profile
shipwright
8055 posts in 2912 days
#5 posted 02-27-2017 02:56 PM
If you have the clamping facilities I would suggest OBG but if you don’t want the clamping issues it is a good application for hammer veneering with HHG. That said there is a learning curve for hammer veneering.
Don’t worry about the strength of HHG.
