English woodworking bench using plywood
Forum topic by JoshuaS posted 02-25-2017 04:51 PM 1709 views 1 time favorited 17 replies Add to Favorites Watch
View JoshuaS's profile
JoshuaS
15 posts in 841 days
02-25-2017 04:51 PM
I’ve got a plan to build a Paul Sellers bench using 1” thick Baltic birch ply. Sketchup images attached. I’ve seen other bench designs using plywood that have mortise and tenon joinery, but this is taking it a bit further and I’m wondering if it’s ok. Do you think this will result in a solid bench? Assuming, of course, that I can make the joints fit tightly…
17 replies so far
View TheFridge's profile
TheFridge
9603 posts in 1507 days
#1 posted 02-25-2017 04:55 PM
I think that would be a pretty solid bench. It only looks like maybe 3ish sheets of 1” ply so the cost wouldn’t be too bad I guess.
View RustyHacksaw's profile
RustyHacksaw
142 posts in 1285 days
#2 posted 02-25-2017 05:40 PM
The cost of that seems way higher than if it were 2×4’s like the original. Is there a benefit to the plywood?
But yes, I would say it would be plenty strong.
View bondogaposis's profile
bondogaposis
4753 posts in 2372 days
#3 posted 02-25-2017 05:41 PM
I’m quite sure it will be solid. It certainly won’t look traditional. I seems to me that building up the legs and stretchers will be a lot of additional work compared using lumber for those components, that wouldn’t be worth the small savings in materials to me.
-- Bondo Gaposis
JoshuaS
#4 posted 02-25-2017 07:39 PM
Thanks for the replies. Two 4×8 sheets are $300, so that’s about three times as expensive as 2×4 construction. However, it should be almost twice as heavy, very stable, and if I did the cut list right there should be enough plywood left over for a small tabletop project.
View Woodknack's profile (online now)
Woodknack
11758 posts in 2401 days
#5 posted 02-25-2017 10:38 PM
It’ll be fine. Rob Cosman, a very respected woodworker, has a bench built from MDF. It’s not his only bench, but he built it to try it out and has a video about it.
View FLFIRELT's profile
FLFIRELT
2 posts in 699 days
#6 posted 02-25-2017 11:40 PM
Looks like a solid plan to me.
Out of curiosity how much is 3/4 Baltic birch? It’s been a while since I’ve bought 1” but I seem to remember a huge price jump from 3/4 to 1”. Just a thought to maybe save some cash by changing dimensions a little and possibly getting it even beefier.
View xmastree's profile
xmastree
47 posts in 1001 days
#7 posted 02-26-2017 01:46 AM
Out of curiosity how much is 3/4 Baltic birch? It s been a while since I ve bought 1” but I seem to remember a huge price jump from 3/4 to 1”. Just a thought to maybe save some cash by changing dimensions a little and possibly getting it even beefier.
- FLFIRELT
That’s what I was thinking..
-- Every tree is a Chistmas tree with its gifts hidden inside.
JoshuaS
#8 posted 02-26-2017 03:15 AM
Thanks a lot for the input, you’ve given me the confidence to proceed. I did consider 3/4” but that will require more cutting and laminating. If the extra cost means I can bang it out faster then it’s worth it to me.
Cheers!
View robscastle's profile (online now)
robscastle
5070 posts in 2225 days
#9 posted 02-26-2017 03:24 AM
I think all the gypsy’s trailers were built from plywood
-- Regards Rob
View shipwright's profile
shipwright
7992 posts in 2819 days
#10 posted 02-26-2017 03:28 AM
I have a great solid plywood workbench. Your joinery ideas seem quite similar. You may want to have a look at the build blog here: http://lumberjocks.com/shipwright/blog/31955
The project post is here: http://lumberjocks.com/projects/70677
View nkawtg's profile
nkawtg
277 posts in 1273 days
#11 posted 02-26-2017 03:33 AM
Solid, yes. But I’d be worried about flatness.
JoshuaS
#12 posted 02-26-2017 04:40 AM
Beautiful work there! Thanks for the links.
I thought about covering up the ply edges but in the interest of speed I’ll just go with them. Baltic birch doesn’t look too bad in my view.
- shipwright
JoshuaS
#13 posted 02-26-2017 04:43 AM
I’m counting on the BB being flat. Shouldn’t it be?
Solid, yes. But I d be worried about flatness.
- nkawtg
View clin's profile (online now)
clin
849 posts in 1017 days
#14 posted 02-26-2017 06:59 AM
I built a workbench base by laminating baltic birch. Here’s the link to the project page. Solid doesn’t begin to describe it. It’s absolutely rigid. I can raise one leg 1/32” and the nearest leg will rise up the same amount. No detectable flex in the frame.
Most of this project describes making the torsion box top, but there’s a pic of the base in it.
Click for details
Laminating the plywood has the advantage of giving you very precise mortises. The laminating is a lot of extra work. You need a lot of clamps, and likely need all your clamps for one piece at a time. So it will take several days just to clamp, assuming you leave them in the clamps for at least a few hours.
I wouldn’t make the top from plywood. it’s not uncommon to have to flatten a top by hand planing, or more elaborate techniques. That’s not something you can do to plywood for effectively.
If you are inexperienced making mortises, I would say it is easier to laminate the legs, then to cut mortises, But, a workbench build is a traditional first project and a good one to get experience on. So, I would give serious thought to making it traditionally. Also, consider using drawbores on the M&T joints if you cut them yourself, not if you use plywood. That will make very tight M&T joints.
-- Clin
JoshuaS
#15 posted 02-27-2017 05:56 AM
That’s an awesome build.
Yes indeed! I’m still on the fence…
