Cutting Plexiglass
Forum topic by WoodNuts posted 09-29-2010 02:52 PM 1535 views 0 times favorited 10 replies Add to Favorites Watch
View WoodNuts's profile
WoodNuts
74 posts in 2912 days
09-29-2010 02:52 PM
Do you get a good clean cut with an 80T blade when cutting plexiglass?
Any issues?
-- ...there's a fix fer dat...
10 replies so far
View j_olsen's profile
j_olsen
155 posts in 3135 days
#1 posted 09-29-2010 03:27 PM
WN—I do it quite often—I find that a slow steady feed rate and a zero clearance insert work the best
-- Jeff - Bell Buckle, TN
View quartrsawn's profile
quartrsawn
146 posts in 3176 days
#2 posted 09-29-2010 03:35 PM
I cut it on my table saw with a 10 in. combo blade , works fine.
-- Nat - West Sayville,L.I., NY
View Gene Howe's profile
Gene Howe
10349 posts in 3392 days
#3 posted 09-29-2010 04:18 PM
I like to leave the paper on or tape the cut. It seems to give a cleaner cut with less melting.
I also use an 80T blade.
View Tracey615's profile
Tracey615
19 posts in 2762 days
#4 posted 09-30-2010 07:02 PM
I cut the piece for the opening about 1/16” large. Then use my old jointer to finish to size. Works well for me. Not too good on the jointer. It is an old 4” x 24”, it leaves a scolloped edge which is easily scraped smooth.
-- Trace the Bald
View richgreer's profile
richgreer
4541 posts in 3038 days
#5 posted 09-30-2010 11:38 PM
FWIW – Thinner plexiglass can be cut quite easily with hand tools. You need a scoring device. I’ve had pretty good luck with that and I get cleaner cuts than with a power saw.
I know we are all in love with our power tools but for somethings, hand tools work better.
View smgaines's profile
smgaines
22 posts in 2764 days
#6 posted 09-30-2010 11:57 PM
I’m with Gene tape it up and it should cut fine. If the plexi doesn’t have a protective film on it tape some paper to it. I had to recut a piece one time because the table saw top scratched it up.
-- Scott, Georgia
View snowdog's profile
snowdog
1164 posts in 3946 days
#7 posted 10-01-2010 02:04 PM
I heard that if you turning the blade backward it will cut the plexi without chipping. I tried it a few times and it seemed to work well. Good ventilation is always a plus :)
View surfin2's profile
surfin2
51276 posts in 3099 days
#8 posted 10-01-2010 11:53 PM
You have more of a chance of it chipping (plexi) backwards…
I’ve used 80t finish blade & router with perfect results…
-- Rick
View firecaster's profile
firecaster
572 posts in 3382 days
#9 posted 10-02-2010 01:42 AM
I’m with Rich. I use a hand held scoring tool and a straight edge. Lexan (polycarbonate) has to be cut with power tools I think.
-- Father of two sons. Both Eagle Scouts.
View Abbott's profile
Abbott
2570 posts in 3267 days
#10 posted 10-02-2010 02:20 AM
I cut Plexiglas regularly on my table saw with no troubles, it just needs to be fed slowly into the blade.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
