Jointer Belt Tension? Delta 37-205
Forum topic by Lt_scout posted 02-25-2017 05:31 AM 429 views 0 times favorited 4 replies Add to Favorites Watch
View Lt_scout's profile
Lt_scout
37 posts in 477 days
02-25-2017 05:31 AM
Hey guys,
I bought a Delta Milwaukee 6” jointer 37-205. I bought a new top pulley from Canadian tire and the belt is pretty tight, very tight, it’s gets warm after a minute or two of use.
How tight can you run these V belts?
-- When you know you can do more with less, you will require less to do more.
View TheFridge's profile
TheFridge
8894 posts in 1393 days
#1 posted 02-25-2017 06:05 AM
Pretty tight. It’s gonna get warm. It’s been hard to do what I’d consider over tightening on my machines. I’d have to use a cheater bar or something.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3619 days
#2 posted 02-25-2017 06:32 AM
As long as you don’t smell hot rubber when you are running it I think the belt is probably cool enough.
View WhyMe's profile
WhyMe
981 posts in 1467 days
#3 posted 02-25-2017 03:29 PM
Lt_scout
#4 posted 02-25-2017 04:14 PM
OK that is good to hear, before changing out that top pulley the belt flapped and chattered a lot. Tight, it runs much smoother.
