Dado Back of Faceframe & Pocket Screws
« back to Joinery forum
Forum topic by Scott posted 02-24-2017 12:23 PM 1167 views 1 time favorited 21 replies Add to Favorites Watch
View Scott's profile
Scott
111 posts in 1438 days
02-24-2017 12:23 PM
I’m starting to plan out my kitchen cabinet build that will happen in the next few years. My question today is about attaching the faceframe to the carcass. The method for attaching the faceframe will be pocket screws. But does anyone also dado the back for the faceframe to get a more seamless look? I’ve seen this done on a few high end cabinets. And yes, whenever I go to someone’s house, I peak at how their cabinets were constructed lol
21 replies so far
View rwe2156's profile
rwe2156
3034 posts in 1563 days
#1 posted 02-24-2017 01:17 PM
I only build frameless cabs but my initial reaction is “why?”
My real question is why the heck are you looking inside peoples cabinets for something not even noticeable?
There may be larger issues here LOL.
Oh, jeez, did I just take some bait?
View RockyTopScott's profile
RockyTopScott
1186 posts in 3561 days
#2 posted 02-24-2017 02:40 PM
I have done both Scott. The dado became overkill for me. Now I glue the FF and pocket screw from top stretcher and bottom shelf. May a few pins to keep it aligned while I put in the screws. don’t overthink faceframes, they don’t have to be indestructable.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View GR8HUNTER's profile
GR8HUNTER
4336 posts in 795 days
#3 posted 02-24-2017 03:13 PM
IMHO ….the only cabinet to build is Frameless …. good luck to you sir :<))
Scott
#4 posted 02-24-2017 03:27 PM
rwe2156, haha I don’t look in people’s cabinets to see if they have a dado. I just look at them (from a distance) for general construction. I usually do this with any furniture I see. I’m just curious how it went together and try to get ideas for projects for the future.
View TungOil's profile
TungOil
991 posts in 577 days
#5 posted 02-24-2017 03:42 PM
I do both. the dado helps assure the sides of the cabinet are straight and true and gives me a bit more glue surface. I run some pocket screws in from the outside face to pull everything together. Since I use pre-finished birch for all of my carcasses now this gets me to “done” much faster. For cabinet sides that show I cover up the end with either matching PSA veneer (cheap/easy) or a raised panel screwed in from the inside.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View pintodeluxe's profile
pintodeluxe
5736 posts in 2896 days
#6 posted 02-24-2017 04:01 PM
I assemble the face frame itself with pocket screws, but attach the face frame to the carcass with biscuits and glue.
It works great.
Just glue and clamps works fine too.
View Loren's profile
10477 posts in 3730 days
#7 posted 02-24-2017 05:17 PM
with 3/4” thick cabinet sides I think it’s fine
to eliminate dados.
Some of these t&g type construction techniques
are better suited to light weight cabinets with
1/2” sides, imo. They used to be made that
way to save costs and weight for installation
in high-rise buildings but these days the 3/4”
side is king.
View cabmaker's profile
cabmaker
1738 posts in 2891 days
#8 posted 02-24-2017 10:42 PM
Dado ? How would that possibly help ? and where would you dado a face frame ?
TungOil
#9 posted 02-24-2017 11:23 PM
the dado runs vertically up the back of the face frame where the side meets the back of the frame. It helps in two ways- first it forces the cabinet sides to be straight even if your ply has a slight bow and second it adds about 3x the glue area compared to a simple butt joint.
I build mine with a 3/8” x 3/8” dado in the face frame that mates to a corresponding rabbet in the carcass side.
View pontic's profile
pontic
622 posts in 691 days
#10 posted 02-24-2017 11:46 PM
I use case built frames mostly. and no face frames. Dado the shelves upper and lower on the upper cabinets. Lower cabinets I run a dado on the floor just above the toe kick and frame above to support the top. Back is rabbeted 1/4” ply. All drawers on the bottom. Older clients like them better.
-- Illigitimii non carburundum sum
View mat60's profile
mat60
34 posts in 538 days
#11 posted 02-27-2017 01:11 AM
Im with TungOil.
Scott
#12 posted 02-27-2017 01:48 AM
For those of you that douse dado, how do you cut them? Do you use a router jig?
TungOil
#13 posted 02-27-2017 01:56 AM
I cut my dados with a dado stack on the TS. It’s the easiest for me (and doesn’t fill the shop with dust and chips). I cut the dado for the face frame, flip the panel and cut another for the back to slip into. quick and easy, all done with one setup.
A router would work too, but would make a bigger mess.
View JBrow's profile
JBrow
1366 posts in 1002 days
#14 posted 02-27-2017 04:26 AM
Scott,
I am following TungOil’s prescription; dados in the face frame at the table saw that slip over rabbeted tongues in the plywood sides, and bottom (and top if an upper cabinet). I try to cut the rabbeted plywood tongues a little too large to fit the dado and then fine tune the rabbeted plywood tongue with a shoulder plane for a snug fit. I also use the dado/rabbeted tongue joint to connect the sides, back and bottom (and top if an upper) of the cabinet.
It helps a lot in producing a square cabinet when it is time to glue things together. It takes some time but then I am building cabinets for our own kitchen and thus I am liberated from the constraints of a production shop where time is money.
Scott
#15 posted 02-27-2017 12:29 PM
TungOil, wouldn’t you see the dado on the bottom of the stiles? I”m thinking of upper cabinets. Yes you’d have to be looking for them in order to see them. That’s why I was thinking people do it on a router.
