Brand new to wood... almost.
Forum topic by Seanroze posted 02-24-2017 04:07 AM 612 views 0 times favorited 7 replies Add to Favorites Watch
View Seanroze's profile
Seanroze
5 posts in 508 days
02-24-2017 04:07 AM
Hello to everyone. I am new to wood working and have completed one simple built in with floating live edge maple bench so far. It turned out nice I think, and I really enjoyed the time I spent doing it so I guess I’m hooked.
Now, as to my dilemma. I very recently acquired, very inexpensivly, some very beautiful figured maple slabs that I wish to turn into a table and benches.
The pictures don’t do it justice, it is rough sawn and still shines it is very figured and burl’y. The problem arises because, it was felled a couple years ago but milled a year and a half ago and stored in a garage in the Oregon high desert (by the person I got it from) it was a 13’ slab and cut in half the ripped down the middle for the benches. The benches are in great shape but the big slab is cupped very much. I am wondering what kind of fix there might be for it at this point. I’m down for anything, even hand planning the whole thing if I have to. But if I could find a less labor intensive method I would like to. The cracks and checks do not bother me, I actually have big plans for them, so if what needs to be done causes more I wouldn’t hate it.
The big slab is currently 6’ 6” x 36”x 3”
Anyway. Thanks for your time.
I’ll be looking for design ideas soon as well.
-- I hear only half, what had I heard the whole, would understand but half.
7 replies so far
View Aj2's profile
Aj2
1497 posts in 1849 days
#1 posted 02-24-2017 05:22 AM
There’s no fixing wood that’s cupped.
But you can build a router sled contraption to flatten it.
The rest is up to you.
Aj
-- Aj
View Lazyman's profile
Lazyman
2160 posts in 1438 days
#2 posted 02-24-2017 05:27 AM
Check out router planing jigs. It’s going to to take awhile with anything that big no mater what approach you take.
View BurlyBob's profile
BurlyBob
5627 posts in 2316 days
#3 posted 02-24-2017 05:39 AM
Sean, if you decide to give up on these. Get in touch with me. Prineville is not to much of a drive. I’d be happy to take them off your hands.
Best of luck with your endeavors. Those are going to be something awesome.
Seanroze
5 posts in 508 days
#4 posted 02-24-2017 06:24 AM
Burlybob. “Those are going to be something awesome”
I know
Just add water…the entire slab looks like this.
View CustomBuild's profile
CustomBuild
2 posts in 508 days
#5 posted 02-24-2017 07:42 AM
Use a router sled. Make sure you get a large diameter planing bit for the router.
It will not take very long if you have a bit that is between 1 1/2 inches to 2 inch
Seanroze
5 posts in 508 days
#6 posted 02-27-2017 03:35 AM
Thank you for the replies so far. I thought of a router sled, but do need to know if there is a maximum amount of twist I could or should work with. Aside from the crown/cup issue, the slab has severe twist to it. When I get 3 corners to touch my bench, the fourth is a full 2” above. The slab is 3” thick. My question is. Is it possible I could not have enough material to work with?
Thanks.
Seanroze
5 posts in 508 days
#7 posted 06-03-2017 11:01 PM
Well, I went ahead and gave it a shot. I started with the first bench to my table set. I’ll star on the other bench in a week or two. This one didn’t take too long to straighten out. The other bench has about the same twist but the main slab is really warped.
Here are a couple pics.
