Filling in gaps
Forum topic by kdavid posted 09-28-2010 02:40 PM 1015 views 0 times favorited 2 replies Add to Favorites Watch
View kdavid's profile
kdavid
21 posts in 2893 days
09-28-2010 02:40 PM
Hi all, I had to take the legs of off of a teak table due to failure of one end. Now I am left with holes from the fasteners and also where the glue took up some of the finish and tore uo some partical board underneath.In the pictures you can see the light ares , that’s where the damage is. How can I fill in the areas so they will take reinsertion of the mounting hardware and on the long strip, I need it to be flush and glueable. As always any help is appreciated. Thanks in advance..Kirk David…it seems I don’t know how to load pictures, sorry
-- Kirk..... " Hope I die before I get old "
2 replies so far
View terrilynne's profile
terrilynne
836 posts in 2765 days
#1 posted 09-29-2010 04:36 PM
Take.a.wooden.match.stick,put.a.dab.of.glue.on.it.put.it.in.the.screw.hole.and.break.it.off.
sand.off.the.sharp.ends..
As.far.as.the.particle.board.damage.some.matching.wood.filler.might.do.the.trick.
-- Terri, Rocky Mountain High Colorado!
View SnowyRiver's profile
SnowyRiver
51453 posts in 3352 days
#2 posted 09-29-2010 04:53 PM
I agree with Terri, if you take some match sticks and glue them in the holes, sand, and they should hold screws etc for the hardware. To fill gaps etc, take polyurethane glue and mix it with fine sawdust from the same wood you are working with and press it into the holes etc. It will expand so try not to use too much. Sand and stain.
On the pictures, put your pictures into a site like Photobucket, then copy and past the HTML link to your post.
Good luck !
-- Wayne - Plymouth MN
