Forum topic by jtylerp | posted 09-28-2010 12:38 PM | 1907 views | 0 times favorited | 8 replies | ![]() |
I’m having trouble here. The nut holding the arbor pulley on won’t budge. There’s an indentation in the middle of the arbor shaft and a long indentation on the perimeter of the arbor shaft running parallel to the shaft’s length. Given the trouble I’m having I’m thinking I need to do something with one or both of these indentations to get this pulley off… any tips? -- Tyler, woodworking newbie |
8 replies so far
#1 posted 09-28-2010 04:30 PM |
Make sure you’ve loosened all setscrews, it’s not uncommon for a motor pulley to have two. A pulley can be quite tight on the motor shaft, especially if it’s been on for a number of years. Pulley/gear pullers are cheap and handy to have around. -- The Wood Nerd -- http://www.thewoodnerd.com |
#2 posted 09-28-2010 04:41 PM |
A lot of times those will be left handed threads. That’s so they don’t loosen under a load. If that’s the case, go: Lefty tighty, righty loosey, if ya know what I mean. -- My reality check bounced... |
#3 posted 09-28-2010 11:12 PM |
It’s the arbor pulley on a delta contractor’s saw. The “indentation” is more like a slot… how do keyway slots work? I bet that’s what I’ve got. I’ve tried PB blaster and treating it like a LH thread. thanks for all your help -- Tyler, woodworking newbie |
#4 posted 09-28-2010 11:22 PM |
You might also check for 2 set screws in each location. Its not uncommon to have 2 screws. Give the penetrating oil a chance to go its thing, it may take a day or so. There will be a key way on the arbor shaft. After the set screws are removed you have have to press the pulley off the shaft if it has been there for a long time. -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
#5 posted 09-28-2010 11:31 PM |
A key is a (usually ) square piece of steel stock that fits into the key slot. More than one set screw can be common on pulleys. Also, if the set screws have been over tightened they can bugger up the shaft making it a real pain to get off. The nerd is correct, a puller is a must. Be aware the outer edge of a pulley cant’t withstand much force. Back it up any way you can. |
#6 posted 09-28-2010 11:33 PM |
You need to use a pulley/gear remover with three legs.Easy when you have one the can be stiff.Alistair -- excuse my typing as I have a form of parkinsons disease |
#7 posted 09-29-2010 03:26 AM |
Thanks everybody. Learned a bit more after getting the motor pulley off (not the one I’m having trouble with) because it had a shaft key and set screw. Now I know the arbor pulley and the PIA nut I can’t get off don’t have a setscrew but there is a shaft key slot that the nut doesn’t have a slot for. Think I might end of dremeling the nut… -- Tyler, woodworking newbie |
#8 posted 01-29-2011 02:10 AM |
Did you have any luck removing the nut? I have the exact same problem with my contractor saw. Thanks. |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28054 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
