Sander Question
Forum topic by WoodjoeDrillson posted 02-24-2017 03:24 AM 397 views 0 times favorited 3 replies Add to Favorites Watch
View WoodjoeDrillson's profile
WoodjoeDrillson
1 post in 693 days
02-24-2017 03:24 AM
Topic tags/keywords: sander spindle jigsaw belt wood lathe
So I’ve been using my jigsaw for some projects and because I’m not great at it yet (I’m okay) and because it’s a jigsaw, I don’t always get the smoothest cuts. Sometimes I have some pretty ugly cuts that I would like to smooth over with a chisel or sander. I have a random orbital sander but I’m guessing this isn’t the best sander to use for the edges. My question is, which sander would be best for rough edges that need quite a bit of work? Would it be a belt sander? Or a spindle sander? Or some other sander? or none at all?
Any advice would be appreciated.
Thank you,
Joe
3 replies so far
View HokieKen's profile
HokieKen
7530 posts in 1374 days
#1 posted 02-24-2017 01:45 PM
Depends very much on the type of cut. For straight edges or edges with slight convex curves, a belt or disk sander would be my preference. For concave surfaces or faces with tighter curves, a spindle sander would be the better solution.
-- Kenny, SW VA, Go Hokies!!!
View JBrow's profile
JBrow
1366 posts in 1155 days
#2 posted 02-24-2017 02:01 PM
WoodjoeDrillson,
I agree with HokieKen but do not have a spindle sander. I substitute a sanding drum chucked into the drill press. However, using a sander, rasp, file, or scraper is a slow go. A plane or similar tool like perhaps a spoke shave or curves, would be faster. A plane is easy enough to control, but some care would be required with the spoke shave.
If I need more than one workpiece that has non-straight edges, I like to build a template, using the sanding drum to smooth and fare the curves. I then use a pattern or flush trim bit in the router along with the template to remove mill marks left by the bandsaw or jig saw. If the edges are straight, a straight edge, preferably from wood or a wood-product sheet good, could be used as the router template.
View OSU55's profile
OSU55
2025 posts in 2225 days
#3 posted 02-24-2017 05:34 PM
Might consider a hand plane for straight surfaces, spokeshave for curves. May still need some sanding but much less
