Help - Bandsaw refuses to cut curves, blade just twists
Forum topic by glorysk87 posted 02-23-2017 04:21 PM 715 views 0 times favorited 29 replies Add to Favorites Watch
View glorysk87's profile
glorysk87
11 posts in 578 days
02-23-2017 04:21 PM
I could use some help. I got an old bandsaw from a neighbor and set it up this weekend. I followed a couple youtube videos on how to tune it, so I think I have the guides/thrust bearing/blade position on tire all correct.
But for some reason, when I try to cut anything resembling a curve, the blade just twists as I twist the wood, and refuses to cut anything more than a very very very slight curve. 1/4” blade.
I have a piece for a toolbox i’m building that has some relatively tight curves that I want to cut, and ideally I’d like to use the bandsaw to get them cut as close as possible.
Here are pictures of how I have everything set up: http://imgur.com/a/KYYBw
Can anyone offer advice or help on how to fix this?
29 replies so far
View mrbob's profile
mrbob
182 posts in 689 days
#1 posted 02-23-2017 04:33 PM
Is that blade sharp?
glorysk87
#2 posted 02-23-2017 04:38 PM
it’s the blade that was on it – it doesn’t look like it’s in terrible shape, though it does seem to have a bit of trouble cutting.
mrbob
#3 posted 02-23-2017 04:51 PM
Then I would think it is the blade, they are not that expensive, I would get a new one.
glorysk87
#4 posted 02-23-2017 04:58 PM
Ok thanks, I will definitely try that. Are the blades at big box stores decent quality? Or should I shop online for a much better blade?
mrbob
#5 posted 02-23-2017 05:02 PM
The BB ones are sometimes ok if the are Olsons or Timber Wolf.
glorysk87
#6 posted 02-23-2017 05:04 PM
thanks, i’ll check tonight. if they don’t have those brands, any suggestion where i should buy from?
View Combo Prof's profile
Combo Prof
3656 posts in 1398 days
#7 posted 02-23-2017 05:10 PM
I agree its the blade. The teeth probbaly have no set. Try highlandwoodworking
-- Don K, (Holland, Michigan)
glorysk87
#8 posted 02-23-2017 05:14 PM
thanks, i will try that site – much appreciated.
mrbob
#9 posted 02-23-2017 05:17 PM
Wood Craft, Rockler also
View jbay's profile (online now)
jbay
2604 posts in 1020 days
#10 posted 02-23-2017 05:20 PM
I would check the tension as well. Might not be tight enough.
View Loren's profile
10477 posts in 3768 days
#11 posted 02-23-2017 05:32 PM
+1 on the tension.
The rule of thumb I use is I set the guide at 6”
and press the blade sideways with three
fingers… the fingertips should go white
with only about 1/4” of deflection.
glorysk87
#12 posted 02-23-2017 05:34 PM
Thanks – I think the tension is ok. There’s very little play in the blade when putting pressure on it from the side. But I will check again tonight to see if I should adjust it.
View TheFridge's profile
TheFridge
10131 posts in 1606 days
#13 posted 02-23-2017 05:48 PM
What size blade is that?
glorysk87
#14 posted 02-23-2017 06:44 PM
1/4” blade i believe, 14” saw
View Maximum's profile
Maximum
22 posts in 604 days
#15 posted 02-23-2017 06:54 PM
glory, only check the tension with the machine off… :)
showing 1 through 15 of 29 replies
