Fuming White oak
Forum topic by SawdustJunky posted 09-27-2010 07:13 PM 4957 views 1 time favorited 7 replies Add to Favorites Watch
View SawdustJunky's profile
SawdustJunky
98 posts in 2954 days
09-27-2010 07:13 PM
I’m working on a new project with quarter sawn white oak and I need to fume it. I have read all the instructions and safety precautions so now its time to test a few pieces. One problem….can’t locate any aqua ammonia or ammonia hydroxide. Anyone know I can purchase it or can I use household ammonia? Need a little direction here…..
-- In the end it is more about the memories we make than the pieces we build.
7 replies so far
View FredG's profile
FredG
139 posts in 3659 days
#1 posted 09-27-2010 07:34 PM
Household ammonia will work just fine.
Work with some scrap pieces first to establish the time.
-- Fred
SawdustJunky
#2 posted 09-27-2010 09:07 PM
Thanks guys…........
View samiam's profile
samiam
28 posts in 2766 days
#3 posted 09-27-2010 10:05 PM
Kevin Rodel Wrote in a Finewoodworker article:
This industrial-strength ammonia
is used in machines that reproduce
blueprints and surveys, so you can usually
find it at business-supply, blueprint-supply
or surveyor-supply stores (look in the yellow
pages for a supplier).
If you can get a hold of the article I’m sure it would be helpful too.
http://www.finewoodworking.com/fwnpdf/011126046.pdf
SawdustJunky
#4 posted 09-27-2010 10:21 PM
Got it….picked up some household ammonia today so I’ll test a couple of pieces tonight and see what happens.
Thanks
View gene's profile
gene
2184 posts in 3846 days
#5 posted 09-30-2010 03:50 AM
Hi! Sawdust,
Check out this link that I ran across at Rockler. Hope it is informative.
God bless
-- Gene, a Christian in Virginia
View Dark_Lightning's profile
Dark_Lightning
3141 posts in 3071 days
#6 posted 09-30-2010 04:02 AM
Household ammonia, if it is “lemon-freshened”, is sure to disappoint. The citric acid will have neutralized some or most of the ammonia into a neutral salt. Try a janitorial service if you want some floor-stripping power ammonia. As has been mentioned above, ammonia is bad news if handled improperly. I was patinating some copper, and made the mistake of leaning over the tank. Even with a small amount, I was nearly overwhelmed. Be careful with it! It damages you by dehydration. If you walked into a room with an ammonia atmosphere, the responders will wait until the fog clears to get your shriveled, prune-like corpse. Seriously.
-- Random Orbital Nailer
SawdustJunky
#7 posted 09-30-2010 01:00 PM
Picked up plain household ammonia and fumed the oak. It took about 3 hours to do what full strenght would do in 1 hour but the results are the same, a very mello gray tint. Years ago I did some refrigeration work for and ice plant using ammonia as refrigerant so I’m well aware of ammonia’s nasty side. This household stuff is nothing compared to that. But I was faster then, now I’m slower like the HH ammonia so we work well togehter. Ha!.....................Thanks to you all for you helpful advice.
Blessing to all.
