so if i buy the 2 items below, i should be able to use this on my current lathe's 3/4" x 16TPI headstock, and later when i get a larger lathe, just remove the adapter and use it directly on a 1" x 8TPI headstock, correct?
Chuck
https://www.woodcraft.com/products/woodriver-4-jaw-lathe-chuck-w-case-1-x-8tpi?via=573621bd69702d0676000002%2C573621db69702d0676000d9d%2C5763fed669702d6582000b74
Adaptor
https://www.woodcraft.com/products/woodriver-insert-3-4-x-16-tpi?via=573621bd69702d0676000002%2C573621db69702d0676000d9d%2C5763fed669702d6582000b74
also, anyone have any experience with this chuck that can comment on whether or not it's worth the $$$ ?
Chuck
Adaptor
