Routing headboard
Forum topic by MikeOB posted 996 days ago 664 views 0 times favorited 6 replies Add to Favorites Watch
View MikeOB's profile
MikeOB
89 posts in 1319 days
996 days ago
Making a bookshelf headboard for my son. At the moment the top is square. Should I round it over a bit, leave it alone, cove bit? What suggestions do you have on how to finish the top piece…
-- Mike, Portage, WI
View SnowyRiver's profile
SnowyRiver
47635 posts in 1678 days
#1 posted 996 days ago
Mike…I think that would be a matter of personal preference. Rounding over tends to look nice and more finished sometimes, especially if its a more modern or contemporary piece. It also protects the edges from nicks down the road. If you are building something similar to mission style, then the square edge probably would look better. You could ease the edge a bit rather than a complete round over which would be another option.
How are you doing with the flooding…looked like there was quite a bit of it over there in Portage?
-- Wayne - Plymouth MN
MikeOB
#2 posted 996 days ago
making the front page of yahoo and cnn…the north side of the levee is holding up good for now since they redid most of that side about 5-10 yrs ago. The other side wasn’t fixed…its a mess on that side
SnowyRiver
#3 posted 996 days ago
Thanks Mike…good luck over there…I’m sure its got to be quite a mess.
View Gregn's profile
Gregn
1639 posts in 1181 days
#4 posted 996 days ago
Glad to hear your dry there. Use to go through there quite often. Use to lived in Waukesha and have relatives in the area and in Adams.
Depending on the style I would be more inclined to use a round over bit, or a chamfer bit and soften the edges lightly with sandpaper to avoid your son getting hurt. A cove cut will have 2 sharp edges and would be difficult to soften the edges and still look good. Also my opinion, a cove cut wouldn’t look good on 3/4” material on a project like a headboard bookshelf.
MikeOB
#5 posted 996 days ago
thanks for the advice
View suds1421's profile
suds1421
6 posts in 1328 days
#6 posted 995 days ago
On my boy’s bed I used a roundover bit, on the girl’s I just softened the edges with sandpaper.
I like both, it just depends on the look you are going for :)
Either way I would soften the edges a bit so that if they fall on an edge it doesn’t hurt quite so bad.
