Pool Table
Forum topic by eduardo posted 09-27-2010 10:39 AM 1055 views 0 times favorited 3 replies Add to Favorites Watch
View eduardo's profile
eduardo
1 post in 2883 days
09-27-2010 10:39 AM
Anybody knows who can make Philippine Coin Operated Pool table?
-- ed
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3797 days
#1 posted 12-18-2010 04:57 PM
Hmmm, making a coin operated table would be an interesting exercise. You’d have to figure out how to restrict access to balls already played… hmmm lots of details to think about.
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2940 days
#2 posted 12-18-2010 05:03 PM
The white ball is smaller.
All balls go along to rails and into the dispatch bay. The white ball falls between the rails letting you continue play after a white ball sinks.
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View MSD's profile
MSD
20 posts in 2924 days
#3 posted 12-18-2010 08:18 PM
Normally on a coin operated pool table, ones manufactured in the US, they use 2 different types of Q balls. One is a little oversized or larger than the regular balls and the other is a Magnetic Q ball. The magnetic has a piece of steel in it (normally made by Valley) and it’s directed by a magnetic to a different trough. Some companies used a weight separator (not very reliable) that relied on a heavier Q ball and they would work with the magnetic ones due to the extra weigh of steel in it.
Most companies that sell used or reconditioned Pool Table remove the coin mech and the ball gates. If your going to build a Pool Table it would be easier to get an existing unit from an amusement company.
-- If it's true that we are here to help others, then what exactly are the others here for?
