help with band saw blade
« back to Woodcarving forum
Forum topic by Karda posted 02-22-2017 05:57 AM 898 views 0 times favorited 11 replies Add to Favorites Watch
View Karda's profile (online now)
Karda
1145 posts in 610 days
02-22-2017 05:57 AM
Hi a while back somebody here recommended Timber Wolf band saw blades so I got one I love it. However inorder to be able to adjust it the tension has to be as tight as I can get it. If I start the saw with light tension it throws the blade. What kind of trouble am I in if I don’r release the tension when KI am dome. The problem is when IK need to make a quick cut and for get to tighten the blade thanks Mike
11 replies so far
View wuddoc's profile
wuddoc
283 posts in 3774 days
#1 posted 02-22-2017 05:10 PM
There are two groups of sawyers advocating either tension or de-tension. I always instructed my students to de-tension in order to reduce stretching the smaller blades and creating flat spots on the tires especially during vacation breaks. Others claim de-tensioing is hard on blades. You may want to contact Timber Wolf for their opinion. I have spoken with their staff in the past and found them very helpful.
-- Wuddoc
Karda
#2 posted 02-22-2017 05:22 PM
ok thanks
View Rich's profile
Rich
3206 posts in 645 days
#3 posted 02-22-2017 05:53 PM
I always de-tension. It seems to me that, whether it’s good or bad for the blade, it will be easier on my saw and tires. Blades are relatively cheap and replacing tires is a royal pain in the butt.
View Dustin's profile
Dustin
540 posts in 796 days
#4 posted 02-22-2017 05:57 PM
I’m also in the de-tension mindset. To make sure I don’t forget to re-tension the blade, I hang the power cord over the tension bar. Then again, this only works if you unplug your saw after use (which do, due to little hands, even though they’re only ever passing through my shop with one of us).
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
Karda
#5 posted 02-22-2017 07:26 PM
thanks for your insight, I like the cord over tension knob. If that don’t work Ill put a sign by the switch
View mrbob's profile
mrbob
182 posts in 625 days
#6 posted 02-22-2017 07:30 PM
thanks for your insight, I like the cord over tension knob. If that don t work Ill put a sign by the switch
- Karda
I have a note on the table to remind me.
View ClaudeF's profile
ClaudeF
689 posts in 1763 days
#7 posted 02-23-2017 12:44 AM
I also de-tension my Timber Wolf blade. The instructions from Suffolk Mach. indicate that not as much tension is need ed as other blades. I have actually forgotten to tension the blade and it sawed just fine. Is the blade coming off the wheels while you are pushing the wood into it and cutting? Or, is it only when backing out of a cut? If the latter, I turn off the saw before attempting to back out of a cut. I hold a dowel against the blade teeth to keep it in the guides as I wiggle the wood around to back out of the cut. I’ve lost a couple of blades by carelessly attempting to back out of a cut with the saw running. This was on 3 inch basswood – turns out that the sawdust was filling up the cut an inch or so behind the running blade and when I tried to back out, it just pulled the blade off the wheels and broke it.
Claude
-- https://www.etsy.com/shop/ClaudesWoodcarving
View CharlesA's profile
CharlesA
3332 posts in 1854 days
#8 posted 02-23-2017 01:16 AM
According to Alex Snodgrass, de-tensioning has no effect on saws or blades. He recommends it bc he says that leaving tension on flattens the tires a bit and that the saw will run rough for a bit when used again.
View Jim Finn's profile
Jim Finn
2661 posts in 2978 days
#9 posted 02-23-2017 01:24 AM
I use my 14” Grizzly band saw every day and never un-tension the blade. I use 1/2” Supercut blades and sill have the original tires that came with the saw that I bought in 2008. (nine years ago)
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
Karda
#10 posted 02-23-2017 01:26 AM
ok thanks for the suggestions, I don’t use it a lot so i guess i’ll loosen the tension and put a sign by the switch
View Rich's profile
Rich
#11 posted 02-23-2017 01:32 AM
- Jim Finn
I replaced the original tires on my 1952 Atlas Press Co. band saw just last year. When chunks of rock hard rubber some flying out, you know it’s time.
