52 by 110 table table top challenge
Forum topic by WoodwolfAtl posted 02-22-2017 03:57 AM 825 views 0 times favorited 4 replies Add to Favorites Watch
View WoodwolfAtl's profile
WoodwolfAtl
39 posts in 1753 days
02-22-2017 03:57 AM
Topic tags/keywords: table top
Im building a dining table. it’s 52 wide by 108 long. No typos
it’s broken into 4 glued up sections of 8/4 stock. Each section is 52” long. 2 sections are 22 wide. The other 2 are 32 wide.
Glue up of each was decent but nowhere near flat for table top
Whats the best way to get all 4 sections of equall thickness? after glue up each is about 1.5 inch thick I’m aiminno for final thickness of 1 3/8 to 1.5 inches
I’m afraid I bit more than I can chew
Any tips would be greatly appreciated
View papadan's profile
papadan
3584 posts in 3516 days
#1 posted 02-22-2017 04:37 AM
You are going to need a good hand plane and someone to teach you how to use it.
View pintodeluxe's profile
pintodeluxe
5757 posts in 2961 days
#2 posted 02-22-2017 04:47 AM
Forget a hand plane on a top that big. I would trim the width to 50” and find a commercial shop that can plane it for you.
I use a shop with a 50” helical head planer / drum sander. In just a couple quick passes, my panels emerge flat and smooth. All I need to do is sand it with a ROS .
Good luck with it.
View AandCstyle's profile
AandCstyle
3165 posts in 2404 days
#3 posted 02-22-2017 10:49 PM
Woodwolf, Willie provided the best solution, but if you absolutely need it to be 52” wide, you could make a router sled like is used to flatten slabs. HTH
-- Art
WoodwolfAtl
#4 posted 02-22-2017 11:20 PM
Thank you all very much for your advise
