Question on hinges on end grain
Forum topic by Tito98 posted 02-22-2017 03:44 AM 901 views 0 times favorited 4 replies Add to Favorites Watch
View Tito98's profile
8 posts in 499 days
02-22-2017 03:44 AM
Topic tags/keywords: hinges jewelry armoire
I am making a wall hanging jewelry armoire and attached the hinges for the door. The door is fairly heavy as it has the mirror, 3/4 inch plywood frame and 1/4 plywood backer on the back of the mirror. My concern is the half inch screws that came with the hinges will not hold as its screwed into endgrain of the red oak plywood. Should I try longer screws or maybe add a long hinge on the inside, or any other ideas you all may have. Attaching some photos to try and help show what I am talking about. Thank you!
View cutmantom's profile
401 posts in 2968 days
#1 posted 02-22-2017 03:55 AM
Longer screw should work, be sure to drill a properly sized pilot hole
View Rich's profile
2472 posts in 522 days
#2 posted 02-22-2017 05:49 PM
- cutmantom
Agreed. Even if it did come loose, you can put some epoxy in the hole and run the screw back in.
-- No matter how much you push the envelope, it'll still be stationery.
View bondogaposis's profile
4636 posts in 2284 days
#3 posted 02-22-2017 06:52 PM
You could just add another hinge or go with piano hinge. Actually screws in end grain plywood hold just fine.
-- Bondo Gaposis
8 posts in 499 days
#4 posted 02-23-2017 12:28 AM
Thank you all, my main concern was the door pulling out the screws and damaging the wood. Think I will go buy some longer matching screws
